SpoolinPerf. Blemish manifolds- Turbo Specific Tubulars
These manifolds must use the turbos stated otherwise the setup will not work. Any issues with the manifolds will be revealed with each purchase. These are not made to order. just old returns that didn't fit specific turbos. I tested each one out to see which turbo will work with what. manifolds are brand new
1) D-series quick4AC works with 5-bolt turbine housing turbos only ( Garrett and Precision, not Ebay types)SOLD SOL DOSLD 3) D-series quick4AC 5-bolt t3/To4B housing turbos with 38mm gate only. up to 2.5 downpipe only and will not fit with AC unfortunately** customer fiberglass wrapped it and sprayed with ceramic paint. hence the black areas but item is brand new 350$ http://i138.photobucket.com/albums/q...e/IMG_4927.jpg 4) D-series quick4 AC will not fit AC or PS. up to 2.5 downpipe if your able to bend the ac line out of the way *( did not try on our part) must run a 5-bolt turbine housing with compressor- t04E or T04B housing only 400$ http://i138.photobucket.com/albums/q...e/IMG_4928.jpg http://i138.photobucket.com/albums/q...e/IMG_4929.jpg 5) B-series quick4AC for --SOLD 6_ B-series quick4AC for integra chassis only- SOLD SOLD SOLD |
Re: SpoolinPerf. Blemish manifolds- Turbo Specific Tubulars
Nice wish they would work with holset turbos
ttttttt
ttttttt
ttt
Originally Posted by Mr.Spec
(Post 42439857)
ttttttt
yyyyyyyyy
ttttttttttttttttttt
rtttttttt
ttttttttttt
For the B-series, whats the dif. between the E and the S? Will either of them fit a t3/t4?
ehousings are a 2.75 inlet 2 inch outlet with a smaller overall physical diameter. S housings have a 4 inch inlet with a 2.5 outlet with a larger overall diameter
ttttttttttttttttt
ttttttttttt
tttttttttt
Damn..where's all the blemished top mount manifolds... hahaha jk
GLWS :thumbup: |
i need h22 a/c compatible
its not listed here. i dont have any
TTTTTTTTTT
good deals
thanks !
ttttttttt
ttttttt
tttttttt
tttttttttttttt
