Parting out Honda H-series turbo kit and Built motor
MAKE AN OFFER STILL TRYING TO KEEP THINGS TOGETHER. I WANT THIS GONE I HAVE A TOY NOW.
The motor has 4,000 miles on it and the turbo kit has 3,000 miles on it come out of a 1995 civic coupe. Everything on the car was done by AV-Engineering. http://www.av-engineered.com/site/pr...-h22a-eg-coupe
The Motor- $3800 obo (For Bottom End & Head)
87mm bore
H22a1 block
ACL Bearings
Crankshaft was polished
ERL sleeved the block
CP Pistons 9.0:1 compression pistons were coated
Carrillo Super A-Rods
ARP Head Studs
The head was done by headgames and has been ported and polished with a manley valvetrain with stock size valves and cams
Turbo Kit- $4000 obo
The turbo kit will come with the oil feed line, the water lines for the turbo and all the couplers and bolts and gaskets will come with the kit
H22 Full-Race Top mount manifold T4 flange
Tial 44mm Wastegate V-band
Tial 50mm blow off
Full-Race back door intercooler
T4 Precision GT3582R V-Band
2.5 inch intercooler piping
3.5 inch Downpipe O2 bung welded in
Transmission $1000 obo
H23 with Quaife (LSD) the tranmission has been refreshed
If you have any questions send me a PM
OR
You just can buy my whole car and I know it is in primer but I do have the paint and the rest of the stuff that goes on the car. This is what will come with the car if bought as a whole. I am sure I am missing some things but cant think of anymore if you have any questions just PM me. Email TYNERJOS@aol.com
PRICE 8,300.00
Engine
ERL sleeved block
CP 9.0:1 Pistons
Carrillo Super A Rods
Balance Shaft Removal Kit
Port/Polish, SuperTech Valves, Dual Valve Springs, Ti Retainers
Skunk2 Intake Manifold
Skunk2 68mm Throttle Body
Hondata Intake Manifold Gasket
Fluidyne Radiator
HaSport Motor Mounts
Greddy Oil Sandwich Plate
Fueling/Ignition/EMS/Electronics
NGK Blue Spark Plug Wires
MSD Digital 6+ Ignition Box
MSD HVC Coil
Hondata s300
1000cc Precision Injectors
AEM 5 Bar Map Sensor
Apex’i AVC-R Boost Controller
Greddy 52mm Oil Pressure Gauge
Greddy 52mm Boost Gauge
Apex’i Turbo Timer
PLX M300 Wideband
Suspension/Transmission/Drivetrain
Strange Engineering Double Adjustable Shocks
Custom Spring Rates
Prothane Suspension bushings (complete suspension)
Blox Rear LCA
Blox Front Upper Control Arms
Blox Rear Adj Camber Kit
Full-Race Traction Bar
Quaife LSD
Gator Racing Stage 3 Axles
Turbo Kit
Precision GT3582R-SP T4
Full-Race Pro-Am Top Mount Turbo Manifold
Aluminum 2.5" Intercooler Piping Kit
Stainless Steel 3.5" Downpipe
SS Braided Oil Feed/Return Line Kit
SS braidedGT Series Water Coolant Line Kit
Golden Eagle Vacuum Box
Greddy Oil Catch Can
