NEW: Turbonetics Ball Bearing T3/T04B
Listed on eBay here:
Turbonetics Ball Bearing T3 T4 T3 T04B Brand New 400HP Fast Spool | eBay
but I can also deal directly. I am located in Jacksonville, FL if you are interested in local pickup, otherwise I am shipping for free.
Turbo is brand new. Never been run or even bolted up. It is an awesome turbo for someone looking to make a fat powerband and still make 400hp easily.
Moderator
Re: NEW: Turbonetics Ball Bearing T3/T04B
So that Full_Tilt's thread doesn't get locked for not following the rules. (You can't link eBay ads that you've made onto this FS /WTB listing..)
$799.00
Turbonetics model number 10845-BB
This Ball bearing Turbonetics T3/T04B normally retails for $1,165. It has never been used or even mocked up. I ended up using a different turbo. My loss is your gain!
The Turbonetics T3 To T4B/E Hybrid Turbochargers offers the low inertia and fast boost response of the lightweight T3 turbine wheel combined with the high-airflow characteristics of the T4 compressor family. Most T3/T4 Hybrid Turbochargers are available with the patented Ceramic Ball-Bearing option. The Ceramic Ball Bearing T3/T4 Hybrid series offers the fastest spool-up. Coupled with extreme durability, the Ceramic Ball Bearing concept provides the best performance available.
10845-BB Specs:
Compressor Wheel Trim: Super V
Compressor Inlet size: 3"
Bearing Type: Ceramic Ball Bearing - Super fast spool and response!
Cooling: Oil Cooled
Turbine Wheel :F157
Turbine Housing Discharge: Standard 5 bolt
Turbine Housing a/r: .63a/r
Rated at 400hp (at the crankshaft)
$799.00
10845-BB Specs:
Cooling: Oil Cooled
Turbine Wheel :F157
Feel free to make offers.
As far as trades go, Im mostly interested in race prep and equipment. Ive been looking for a set of lightweight 15x7 wheels that will clear my 11" Wilwoods. Anything useful for road racing a CRX, throw it up there, Im open to anything.
I believe the T04B "Super V" compressor is advertised as being a 46 trim. The inducer is supposed to be 2.18" and the exducer 3.0", so 46 trim is pretty close to checking out based on those numbers. I cant find a compressor map for the "Super V", although you can find maps for the older T04B V-trim. This is supposed to be an updated compressor wheel with extended tips to improve flow, making it more "super". lol
My best guess would be that it flows something like 55 lbs/min at the most
According to go-autoworks, where this was purchased from, it is "rated at 400hp".
If youre looking to make right at 400hp, this should be a great turbo. You will have a much better powerband maxing this out than you would making 400hp on a turbo that supports 600hp. Not to mention the ball bearing will make it more responsive and faster spooling than a similarly sized journal bearing.
Moderator
Actually about 46lbs/ min. It's an older design compressor wheel, but will max or at 400-415whp at over 21psi. 24psi, the design starts to surge.
But Full_Tilt is right;it is better to be smaller for close to $400 than to get a 600whp to do 400whp with
^Thanks for the info.
Im a little surprised how little info is available. No compressor maps on the turbonetics website.
I figured it would be similar to this, only with a little better flow capability from the extended tip design.
01DC4
10-05-2012 09:43 AM
01DC4
08-16-2012 08:44 PM
