FS: Journal bearing STC Silver Surfer Mark III BNIB
Have had this sitting for a while but never got around to finishing my set up due to obligations. I haven't even opened the box yet.
The Silver Surfer has returned with a great new compressor wheel profile for the 2013-2014 year, after being in use for almost 10 years! The Silver Surfer is a turbo in a size range that correlates with in the GT(X)3071R-GT(X)3076R Garrett mid-framed T3 footprint. At approximately 59lbs/min, The Silver Surfer gives 1.8-2.4 litre 4-cylinder and 2.5 litre 6-cylinder engine applications the ability to combine the responsiveness needed in the mid-rpm range with additional upper rpm range to reach levels of over 570HP (slightly higher than a GT3076R standard turbocharger) without the possibility of over-surge issues after 28psi of boost pressure, due to its enhanced compressor wheel profile, and well-matched turbine exhaust wheel and ported turbine housing in a T31 footprint. With its T6 -7075 forged aluminum composition, The Silver Surfer has unsurpassed durability to prevent compressor wheel flex that is a typical issue with other "billet" aluminum wheels that are of a lower strength composition. As with all of the STC Forged aluminum series, this turbo gives the reliability, repeatability, and rebuildability that is expected from Genuine Garrett Products This unit has a standard Journal Bearing T31 2.5" turbine housing configuration, which can easily replace the standard T3/T4 Garrett-based turbocharger, and is available in T3 or T4 3" V-band configuration. (T3 V-band is only available using our 2.5" 4-bolt to 3" v-band conversion flange ) The use of 3/8th NPT water fittings for the Journal Bearing version is optional, but highly recommended for those using this turbocharger for "daily driving" duties in which oil temperatures and pressures are put to the test. The Ball-bearing version is optional for an additional charge, and requires the use of a restrictor (.030") and water fittings. * This particular turbocharger is designed best for engine applications that generally plan to run efficiency ranges from 14psi-31psi that plan to run from 380whp-540whp in the standard T04b volute-ported compressor cover. - Journal Bearing Silver Surfer Mark III STC -Woodward -4AN inline oil filter -4AN 90* elbow for Oil filter -4AN 1/8th NPT .060" Oil restrictor -Water Fittings 3/8NPT to -6AN -High temp turbine housing coating black -Compressor cover coating 2.5" 4 bolt flange and gasket included. Asking $1150 + shipping https://cimg4.ibsrv.net/gimg/honda-t...eceea8e97c.jpg https://cimg6.ibsrv.net/gimg/honda-t...b498912564.jpg https://cimg6.ibsrv.net/gimg/honda-t...cf6228a114.jpg |
Re: FS: Journal bearing STC Silver Surfer Mark III BNIB
Bump
bumppity bump
Good stuff
no bites yet for ya?
Originally Posted by TheShodan
(Post 51927720)
Its died down quite a bit in here over the years...
Well, not only that, but Rollo needs to actually show what the turbocharger looks like in its condition, and not just show the box. That might yield a few bites
+1 open the box
