Extra Parts - Pistons, Rods, fuel pump, and more
Going K-Series so now my entire Turbo B-series setup is for sale. Everything is in excellent condition with no issues. I've wanted to go K20 for a while and the wife gave me the green light to spend some money if I sell all of my old parts. I will be adding more items and pictures as I inspect and prep parts to be sold. I have sold a lot of items on here over the years so any doubt please look through my history.
Complete MSD ignition System. New 6AL, wires, SS coil, and dizzy all wired ready to go. Dizzy has new OEM timing pickups in it - $600
Worked great. I ran .023"-0.25" plug gap with over 600+WHP
Victor X - $230 - SOLD
AEM FR & FPR - $180
1400cc injectors -SOLD
70mm TB - $100 - SOLD
SpeedFactory Tucked Radiator complete setup - $650
Doc Race V-Band Top Mount with Dual Turbosmart Wastegates - $700.
I can convert the top mount to T3 or T4 if you would like at no charge.
I know the wastegate placement on the same side is not ideal but space was very limited. No issues with over boosting once second wastegate was added.
Peakboost GSR Ramhorn Ceramic Coated Manifold. Ceramic Coating is maybe 2 months old but heat wrap messed it up a little. No cracks or damage. T3 flange & 2 bolt 38mm WG flange - $375 shipped .
Spearco Intercooler (27.5" x 10.5" x 3.5" core) - $300
Hasport Chromoly Entry Level replacement axles - $285
5-6K Miles. No issues
Avid Torque Mounts with brackets and hardware. $125
Aeromotive Stealth 340 Fuel Pump. Has a few thousand miles on it. - Part number 11142. $100 shipped
ARP 9mm Rod Bolt Kit New. Part # ARP-208-6401 - $60 shipped
Brian Crower Bronze Valve guides New - Part #'s BC3901 & BC3900 - $100 shipped
Skunk2 replica intake manifold. Chrome ceramic coated. Worked great, made 580WHP very easy, was able to make 623whp but took alot more boost. - $125
Civic 99-00 Rear Mount - $50
Starter. Unknown mileage but working fine - $50
Hondata S300 V3 with boost in a P28 - SOLD
Hondata COP complete setup- Used for only a few hundred miles - SOLD
Head: - SOLD
-B18C1,Brian Crower Valves/Springs/retainers,SuperTech Valve seals,Skunk2 LMA,Port & Polished,Stock sized valves,Brian Crower STG2 cams,AEM Cam Gears, Chrome power coated valve cover with two AN fittings welded in
B16 Trans with M-Factory LSD & carbon syncros. GSR 1st & 2nd gear, B16 3rd & 4th, GSR 5th, and original 4.4 FD. - SOLD
AEM Hyper Rod II - Came out of a 500WHP car. No spun bearings, no damage, and come with ARP 2000's - SOLD
JE/SRP Pistons - Was told they were 81mm and 9.4 CR. One piston is one very minor scratch but that's it. - SOLD
ID1000 Injectors - SOLD
Exedy Twin disk with 5-6K of daily driving and some street pulls on freeway - $800 - SOLD
Hasport Civic B-Series mount 70A- $265 - SOLD
AEM FR & FPR - $180
Head: - SOLD
