9:1 SRP Pistons (D series)
SRP Pistons w/ brand new never used rings
will fit all D series blocks. pistons are in great shape as you can see in the pics. not sure about the mileage,they were purchashed from a member on this board and i ended up not using them. 75.50 mm bore (.20 over) part # 149190 comp ratios: Part # 149190 D16a6=9.5 c/r D16z6=10.2 c/r D16y8=9.0 c/r more info: http://www.jepistons.com/pdf/2...a.pdf SOLD http://www.imagestation.com/picture/...6/f9a43c62.jpg http://www.imagestation.com/picture/...6/f9a43c63.jpg Modified by quis23 at 2:12 PM 2/24/2004 |
Re: 9:1 SRP Pistons (quis23)
up for friday!!
Those are for the A6 and nitrous on a standard bore.
Bore Over Stroke Rod Comp Head Comp Dome Gram Foot Part Required MM / Inch Size Length Height CC Ratio Volume Weight Notes Number Ring Set 75.00 2.953 STD 3.543 5.394 1.161 38.0 9.5:1 -2.9 233 V 149190 JXC0F4-2953-2 V stands for nitrous T would be the turbo and nitrous |
Re: 9:1 SRP Pistons (PornstaR16L)
you are referring to the doomed pistons. for some reason
they have the same part # i am not not selling those,i'm selling these-- http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg which by the way are SOLD https://honda-tech.com/forums/images/smilies/emthup.gif |
