need lots of help with my 87 crx si
im trying to change the clutch and lets just say that bitch pin lives up to its name. i dunno how to get it out its being such a pain in my *** , also , i've been using the manual and i have no idea where the speedometer cable or any of the other wires/ linkages are to remove it. i also need to know where the heck the starter is so i can get that off to any help would be appreciated
Screw you guys, I'm... going... home.
Re: need lots of help with my 87 crx si (veritasaequatis)
First, the bitch pin: yeah man, they reeeaallly suck! Don't try to hammer it out too hard while it's still in the car or you might break the aluminum housing where the shift rod goes into the tranny. Undo the other end (the one under the shifter) and take the rod out with the transmission and engine. Then when it's all out, support the bottom side of the rod with the bitch pin in it with a socket or something, spray it good with WD-40/PB Blaster/etc, and go ape **** on it with a properly sized punch and a BFH. Again, be sure the bottom of that rod is supported or you'll just bend it or hammer it out the side of your transmission.
The starter is on the upper rear side of the transmission. As far as the speedo cable and other wiring, go to http://www.redpepperracing.com, click on "Manuals" at the top of the page, and read the manual.
The starter sits right next to the dizzy. Just look towards the firewall and there it is.
The speedo cable is on the firewall side of the tranny, facing the firewall.
BrokenRex
10
01-20-2006 12:06 AM
