Honda S800 F20c - Page 3 - Honda-Tech - Honda Forum Discussion
Classic Hondas All Pre-1988 Hondas.
Honda S800 F20c
Old 09-16-2015, 05:47 PM
  #51
Bozwell's Avatar
Default Re: Honda S800 F20c
mocking up the double antiroll bar.
shock has a strange bottom mount to make it align. would work better if the mount was centralised but I thought i'd try it to see how it works and if it works ok.
the top mount is shortened so the top of the shock leans in further.
shock is rose jointed so will have rubber o rings on the bottom spacers to keep it steady.
Bozwell is offline
Old 09-16-2015, 06:24 PM
  #52
Kuroneko's Avatar
Love this stuff!
Kuroneko is offline
Old 09-18-2015, 09:04 PM
  #53
Steve at Heart
Bently_Coop's Avatar
Awesome build.
Love the cleanliness and the updated interior.
Bently_Coop is online now
Old 09-20-2015, 12:20 AM
  #54
Blue-Civic-Hybrid's Avatar
Wow, who would have thought some welding rod would look so awesome on a dash??
Also a question about your dual roll bar setup, are you using a custom front sway bar as the secondary one?
Keep us updated, would love to see this car in person one day once it's all done up!
Blue-Civic-Hybrid is offline
Old 09-20-2015, 02:18 AM
  #55
Bozwell's Avatar
iv'e got some spare S800 antiroll bars.
the standard mounts wouldn't take the loading of a very thick roll bar so it'll be on its own mounts. the back end will remain fairly soft in comparison.
next year is the 50th anniversary of the S800 being sold in the UK so it'll be nice to try to get it ready for then.
Bozwell is offline
Old 09-20-2015, 11:30 AM
  #56
Bozwell's Avatar
easy---ish
just needs paint
Bozwell is offline
Old 09-20-2015, 02:36 PM
  #57
Should make for a tight front end, great job.
S600bug is offline
Old 09-20-2015, 08:59 PM
  #58
You may want to check on the road height with the additional sway bar.
From the photo this looks like it may be in serious contention to be ripped off if doing serious driving. The original one is tucked away so that the crash plate is the lowest part of the front of the car.
alex63 is offline
Old 09-21-2015, 04:00 AM
  #59
Kuroneko's Avatar
The additional anti-roll bar would be perhaps 2 or 3cm off the ground on my car. My front license plate hits a few obstacles already for example too. I've lowered my torsion bars two notches, and have the adjusters on setting 4, running 13 inch wheels and 175/60s. A 14 inch wheel might help clearance, but you're likely going to use a 50-series tire? Neko.
Kuroneko is offline
Old 09-21-2015, 10:08 AM
  #60
Bozwell's Avatar
the angle of the photo makes it look very low. it isn't the lowest point on the car.
Bozwell is offline
Old 09-21-2015, 06:15 PM
  #61
Kuroneko's Avatar
Ah ha. I just measured my ground clearance at the front, and it is 9 cm at the front member caps - the lowest point on my car. Neko
Kuroneko is offline
Old 10-04-2015, 02:58 PM
  #62
motacarblog's Avatar
This project is awesome!
Looking forward to seeing more progress.
motacarblog is offline
Old 11-22-2015, 01:28 AM
  #63
Any updates to this beast?
Old 11-22-2015, 05:48 AM
  #64
Bozwell's Avatar
back to fiddly stuff at the moment so not a lot of progress
but so far:
vented disc conversion MK2.
using MK2 hubs and a spacer it's a much neater solution than the MK1 version.
beefier wheel studs for extra strength and makes it easier to get various wheel nuts for the various wheels.
and this is the little MG bearing spacer modified to fit between the S800 bearings.
Bozwell is offline
Old 11-22-2015, 05:53 AM
  #65
Bozwell's Avatar
oh and fitted some home made number plates
Bozwell is offline
Old 11-24-2015, 12:16 PM
  #66
I love this build. Keep updates coming.
ron v is offline
Old 11-26-2015, 04:07 AM
  #67
Icon3 Just awesome
Bozwell, I want to see your S800 in person! It's looking more fabulous at every update!
Old 12-12-2015, 03:39 PM
  #68
Bozwell's Avatar
loads of clearance on the 13inch alloys and clear the standard steel wheel .
should work a bit better than the standard set up and easy to do now I have all the measurements. the MK2 hub is definatly the one to use as it looks a lot tidier than the MK1 version, although the MK1 hub will work.
Bozwell is offline
Old 12-16-2015, 02:41 AM
  #69
94SiRswap's Avatar
Read this thread from the beginning...definitely in on the remainder of this,very cool work you do as well,sounds like a dream job to me.Good luck!
94SiRswap is offline
Old 12-16-2015, 03:56 AM
  #70
ievaq8's Avatar
awesome build ...
ievaq8 is offline
Old 07-08-2016, 11:39 AM
  #71
Bozwell's Avatar
double antiroll bars permanatly fitted
both brakes now done
and to show standard wheels still fit :D
6 speed gearbox modified to fit and for the gear lever to be in the original position (note S800 gear **** :D
the engine being tarted up. will get the rocker cover painted body colour, fit a modified sump then it can go in.
Bozwell is offline
Old 07-09-2016, 03:15 AM
  #72
Oh wow, this is coming together!!
Old 07-09-2016, 09:28 AM
  #73
This is awesome Bozwell! Keep up the great work.
Old 07-13-2016, 03:36 AM
  #74
Kuroneko's Avatar
Inspiring!
Kuroneko is offline
Old 07-14-2016, 12:50 PM
  #75
kp
kp's Avatar
Sooooo good! This thing will be a monster!
kp is offline
Quick Reply: Honda S800 F20c
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
