gas pump problems // carburator /
i have a 1989 honda accord lx 4 door automatic carb.. im having this major problem that i just cant seem to fix or have anyone able to fix it i need some help with this my car runs for about an hour tops than shuts off and i have to wait just bout 45 mins for the car to cool down and then it starts back up which is bothering me so much i cant pin point the problem i have taken it to shops they tell me its the carb.. or gas pump i already had the carburator rebuild maybe thats the problem i dont know and i need help with this asap any info would be highly appreciated thanks for your time .... btw the gas pump has been changed just bout a yr ago
Re: gas pump problems // carburator /
It's either the main relay or the fuel pump relay. Replace them both and see what happens. The solder joint in both of them are weak, and usually if you re-solder them yourself, you can fix them. Or just try another relay.
