89 Honda Accord lxi overheating
I Have an 89 Honda accord... I've replaced the thermostat, sensor n the radiator. . It still continues to overheats. The radiator doesn't get hot enough to turn the fans on. Any suggestions? ??
Re: 89 Honda Accord lxi overheating
Maybe a blockage in the radiator, or the pump has gone bad?
I just replaced the radiator Sunday and cleaned the the tube from the radiator to the overflow. What pump are you referring to?
I also replaced the water pump not that long, a couple of months ago. It was leaking.
Possibly air bound?
You may need to bleed the air out |
If I recall correctly, the air bleed fitting is near the temperature sensor.
Try opening it enough to allow a slight leak of fluid and air (with engine running). When nothing but water sprays out, relighted it. Keep engine running and observe temp gauge and fan/radiator warm up. Be careful of hot water/ coolant! Good luck and let us know. |
Are there bubbles in the coolant? If YES, do a compression test on all cylinders as it may be a head gasket breach which is not at all uncommon for a twenty-five year old vehicle.
