Classic Hondas All Pre-1988 Hondas.
87 crx Help
Old 04-25-2008, 10:44 AM
fico's Avatar
Default 87 crx Help
My friend got an 87 crx and was planning to put an ls in it and boost, what are we going to have to do in terms of wiring, he will be getting s300 to run it so do we need an obd0 to obd 1 harness?
Old 04-25-2008, 12:57 PM
iluvmyef9's Avatar
Default Re: 87 crx Help (fico)
wrong place
Old 04-25-2008, 01:23 PM
jlicrx's Avatar
if it is not an Si model, then you will need, basically, all of the wiring out of a 1g CRX Si and then you will need to do a <U>lot</U> of additional wiring or have someone like Hasport convert the engine harness - you will also need the entire fuel system (tank, lines, pump, etc.) from an 1g CRX Si - you will also need 86-89 Integra knuckles/hubs, along with aftermarket mount kit, custom axles, custom shift linkage and custom exhaust - with the heavier B-series engine, you should also look at upgrading the torsion bars
Reedcrx
11-22-2016 08:25 AM
Lil_Rex
10-12-2007 11:37 AM
1stGenHmlae
03-05-2007 06:42 PM
bigwill_2004
01-19-2006 09:20 AM
Quick Reply: 87 crx Help
