86 lude idle and running problems
Im a nooby so have mercy! i have a 86 lude and when i turn it on it runs rough then smooths out then rough and so forth! when i accelerate it wants 2 shut off then it bogs! I've changed; the spark plugs, wires,rotor cap, battery, alternator and water pump! not sure what 2 check for! could it be a vaccum hose? i only payed $380 for the car and with gas prices i nwould really like it running right! If any one could help me out there i would greatly appreciate it! THANKS! I forgot to mention that it's a single carburated dual side setup! could it be they can be somewhat dirty?
Modified by 86redlude at 6:28 PM 4/27/2008
Re: 86 lude idle and running problems (86redlude)
i was gonna say replace the Throttle Position Sensor but you said its carb'd.. hmm.. could be a dirty carb or the pcv valve.. try cleaning the carb with Carb Cleaner.. check all your vac hoses and lines and keep us posted
Re: (Accord1987)
alright thanks for the tip! and as for the carbs the rebuild kit is $130 bucks! but for sure ill replace the pcv! ill try to post some pics so u can myn diamond in the rough corvette!!!!!!!!!!!!
