3rd gen civic b18 swap need help !!
Hello i have a ek3 b18c in nitrous for dragracing now i always have a weak for the 3rd gen .
So now i want to build everythink from the ek to the 3rd gen What do i have to buy I know i need to buy motormouts hydro kit from hasport Im going to build mij ek pedals in to make it hydro like the new models . And i read that i must buy axles . Cant i use other axles or somthink and what kind of T bracket do i have to use ( EK EG ED ) and can i use my ek shifter i cant find the right name my english is not so good but hope you guys no what i am.saying . For the test im going to use the hol ek electrical system Thanx mike |
Re: 3rd gen civic b18 swap need help !!
hasport mount and axles
oem b16 ek t bracket. custom shift linkage. use old and new weld together... some say 1g teg linkage works.. DA half shaft with SK7 stamp obd0-obd1 ecu jumper harness.. jumper for distributor chipped obd1 ecu remove vss to use stock cluster search redpepper! good luck |
