1980 Civic 1500dx 5 speed
#55
Re: 1980 Civic 1500dx 5 speed
Just the type of feedback I wanted to hear.. ~s
Since I’m a rookie I listened to everybody and took it to a machinist. I even picked a machinist the specializes in engines. Stuff like this is the reason I never take on big projects that I don’t have intimate knowledge of. It doesn’t help that I don’t know anybody locally. Fingers crossed I guess
#56
yea man those water jackets before would have been fine with a fresh gasket tbh they only see 16ish psi for the cooling system he was just trying to sell some work now you have to have the head decked , but it will probably still be fine just took a extra step backward to go forward
#58
I hope its decked when I get it back. Thats the same as resurfacing? I guess on the plus side, I was already gonna commit to the $250 rebuild for pom. It was only $71 more. I hope its flat tho..
#64
The EK1 from 82 and 3 actually had some potential, ports and valves were much bigger despite supposed hp ratings and C/R is low on all the old iron block engunes. If you could source some City turbo parts...
#66
Should handle mild boost just fine, those bottom ends were nice. Heads were limited, 110ish hp for fully built, maybe a bit more with the non-stratified canadian heads. The aluminum 1200s actually had more na potential with those hemi heads, they were basically oversized motorcycle engines. Whatever, 1800lb car.
#68
Figured as much, my ****'s from a few decades ago. We used to chop the tops off early civics and offroad them. Whatever, ******* Pintos are desirable now. Just D the bitch.
#69
#70
#71
Rebuild and adjusted. After seeing the ports I might buy a feeler set to double check
What about those coolant ports tho? At least its flat right?! 🤔 What do you guys think
#73
Shave it's nuts off.
I forgot how tiny those exhaust valves are. My 1st car was a 76 CVCC and it was oddly quick though, ate Celicas and topped out around 102 mph.
Haha, ream those main jets with a guitar string and cram a cherry bomb on the exhaust.
#75
what are the main jets?
