Classic Hondas All Pre-1988 Hondas.
1980 Civic 1500dx 5 speed
Old 01-02-2019, 06:58 PM
  #26
HondaJax's Avatar
Default Re: 1980 Civic 1500dx 5 speed
Thats the plan. Reading/ learning as much as I can now so I csn waste as little cash as possible. I really want to bag the car how much do you think I would have to reinforce the chassis
HondaJax is offline
Old 01-02-2019, 07:49 PM
  #27
dilbeckskate's Avatar
idk man you would have to find a fabricator first and talk to them
dilbeckskate is offline
Old 01-06-2019, 03:22 PM
  #28
HondaJax's Avatar
Stripped the engine down to the block today. Everything went smooth. If I was an actual mechanic I couldve replaced the head gasket and reassembled in 6 hours or less.
The head is off to the shop to be pressure tested and resurfaced tomorrow.
There is a lot of “rusty” colored gunk in the long slottted ports on my block I believe are water ports. How do I clean this out without pulling the engine?
I have 2 sensors Im unsure of their identity. Ill try to post pics for help.
HondaJax is offline
Old 01-06-2019, 03:26 PM
  #29
HondaJax's Avatar
HondaJax is offline
Old 01-06-2019, 03:32 PM
  #30
HondaJax's Avatar
Top pic came out of the old carb
Bottom pic I have no clue. Found it floating around the carb base hooked to nothing
HondaJax is offline
Old 01-06-2019, 03:56 PM
  #31
not reused with the weber carb, you are making kickass progress man keep it up
Old 01-06-2019, 04:59 PM
  #32
HondaJax's Avatar
Originally Posted by Honderachinaldo View Post
Yeah, a properly sorted D would exceed most realistic power requirements in that chassis for the price of a bucket of lard, at least after minor swap issues are resolved.
What sort of issues other than clearance and mounts?
HondaJax is offline
Old 01-06-2019, 05:07 PM
  #33
HondaJax's Avatar
Thanks. I dont need either sensor?
HondaJax is offline
Old 01-06-2019, 06:53 PM
  #34
getting the crap out of the flush just entails doing a good coolant flush with some additive after its running again... and IF I REMEMBER CORRECTLYYYY ones got to do with the electric choke and the other is like a intake temp sensor for cold starts , id figure out which one is 12v switched (prob the one thats single wire) and run it to your choke and ditch the other
Old 01-08-2019, 11:35 AM
  #35
HondaJax's Avatar
Dropped of the head to my machine shop today. My coolant ports are rusted to hell from sitting over the years and require welding 😑
Bad news: I need at least 8 welds
Good news: machinist is from Puerto Rico and owned a similar old honda back home. He has attached himself to the rebuild and quoted me $8 per weld.
$321 with tax for welds + complete rebuild and adjustment. 👍🙂
5 star local engine specialty shop with great reviews. I see why.
HondaJax is offline
Old 01-08-2019, 11:43 AM
  #36
HondaJax's Avatar
D16y8 vtec for sale local for $600 I feel like that’s a lot since he selling two cars; one titled, that motor, and a blown motor for 900
I feel like 6 is a bit much. Should I get it?
HondaJax is offline
Old 01-08-2019, 12:02 PM
  #37
dont even think about starting the swap until you are ready to drop 5-10k to do it all right and where you would pass tech at events
Old 01-08-2019, 01:07 PM
  #38
HondaJax's Avatar
Its not a good idea to accumulate parts? What if the guy will take 450 for it. Its actually an obd1 vtec d16z6. What do you mean pass tech at events?
HondaJax is offline
Old 01-08-2019, 01:49 PM
  #39
most the parts you wouldnt end up using other than motor/trans shift linkage. it would be easiest to be like me and use a obd1 stand alone harness to run everything and you use your stock 80 axles soo at that point you bought a whole donor car that you arent going to use alot and id run the z6 it would be great but you would want to go with a 88-91 cable transmission for ease
Old 01-08-2019, 01:52 PM
  #40
and tech inspection is what you do where they inspect your car pre track/strip day to say its safe , example you have to have approved seats and harnesses and harness bar and correct fuel cell etc theres lots of info out there on whats needed to pass tech inspection
Old 01-08-2019, 03:29 PM
  #41
HondaJax's Avatar
I dont want both of the cars. I just want the engine and I wanna know if 500 or less is a deal. I offered him $450 and I think hes interested. If I had 900 I could buy both cars and engines and scrap everything but the z6 to recoup most my funds. My car piggy is getting a little skinny after all the expenses in the last month: $1500 for the car, $650 in parts, $321 head job $50 miscellaneous. Did I mention christmas money and that I only worked 6 days in 2 weeks over the holidays. What have I done?! Lol
If Im using a newer cable transmission can I upgrade my axles to newer or are my old ones better?
No immediate plans to track the car. More along the lines of a sweet “modern” grocery go kart capable of taking me anywhere. I drive my work truck 80% of the time.
More bad news today. I think I need my block welded 🤬
Gonna try to upload a pic
HondaJax is offline
Old 01-08-2019, 03:57 PM
  #42
HondaJax's Avatar
Do I need welds? Is it weldable?
HondaJax is offline
Old 01-08-2019, 07:58 PM
  #43
dont need no stinking welds. prob fine with fresh head gasket
Old 01-08-2019, 08:33 PM
  #44
HondaJax's Avatar
The head is supposed to have those notches on the coolant ports? Why are they only like that on one side of the block?
HondaJax is offline
Old 01-09-2019, 06:18 AM
  #45
yes thats how its supposed to be , ones intake side ones exhaust side
Old 01-10-2019, 02:48 AM
  #46
HondaJax's Avatar
What is this sleeve? After I took my head off of the car when I was cleaning it, I flipped it over, that fell off the top from somewhere.
HondaJax is offline
Old 01-10-2019, 02:51 AM
  #47
HondaJax's Avatar
HondaJax is offline
Old 01-10-2019, 05:14 AM
  #48
its a pin to align the head and block
Old 01-10-2019, 07:10 AM
  #49
HondaJax's Avatar
Dilbeck for the win. ..Again �� you're proving to be very helpful. I appreciate it. Do I only have 1 pin?
*WARNING: Dumbass ahead*
I may have used a cheap wire cup wheel to clean my iron block. I didnt put pressure and used a battery drill, not pneumatics. On the web it seems around 2011 everyone started saying how bad that is. Is that just because blocks are aluminum now? I imagine ALL 60hp I have is easier to contain than the high hp compression on the newer motors, so I have minutely more room for error? Im just theorizing.
That pic of my block is after I cleaned it with the wheel. How badly did I screw up?
Should I get a sanding block and fine sandpaper to retouch it. If ABSOLUTELY necessary, I will pull the engine and take it to my machinist. Dumbass tax I guess.
if you look at the top left side of the block you can see a raised “bump” this is the only place I tried to use pressure to take off. The block isn’t noticeably scratched and you cant feel scratches with your nail.
HondaJax is offline
Old 01-10-2019, 08:08 AM
  #50
HondaJax's Avatar
Closeup of "bumps
HondaJax is offline
Quick Reply: 1980 Civic 1500dx 5 speed
  • Ask a Question
Question Title:
Description:
