Classic Hondas All Pre-1988 Hondas.
1977 CVCC seats?
Old 11-15-2010, 07:35 PM
wildcard67's Avatar
Default 1977 CVCC seats?
I just bought a '77 cvcc for my sons first car.
It's in pretty rough shape, so we have a lot of
work ahead of us. The interior is pretty much
gone. So, first of many questions. I can't seam
to find any parts for this thing. Are there seats
from other years that will fit?
Old 11-16-2010, 03:30 PM
bob78cvcc's Avatar
Default Re: 1977 CVCC seats?
All 75-79 seats are interchangeable. Later years can also be used with slight modification. 1stgencivic dot com is a great resource for your project. Good luck.
Old 11-17-2010, 05:45 AM
wildcard67's Avatar
Thanks for the info. Does it matter as far as 2 door, 3 door, or hatch?
Old 11-17-2010, 05:59 PM
bob78cvcc's Avatar
The 2 door rear seat may be different from the 3 door. The front seats are the same. You can go to hondapartsnow dot com and put in the different options and you should be able to confirm.
Old 11-17-2010, 07:19 PM
CRX Si69's Avatar
im sure you can fit just about any seat in there if your able to weld new seat brackets in.
Old 11-18-2010, 10:09 AM
wildcard67's Avatar
Yeah, I can weld in new brackets. I was thinking that
having a folding rear seat in a two door might be kinda
cool. It would let haul longer things. I just wasn't sure
if the width and shape would be the same.
Old 12-09-2010, 07:02 PM
77amc's Avatar
Pull the glides off the orig seats, find some BMW ones (thin and light), bolt just the glides back in, weld some flat stock to keep them together, pull back off and adapt them to what ever seat that you might like.
On mine, if I don't just recover, I might just install a single bucket seat in the rear or you can pull off all the foam/cushioning and find some other back seat say, out of a Audi that has some 'contour' to it and re-hogring that on to it and re-n-stall. (looking to do that to my 90 civ 4dr with accord cushioning/fold down rest)
The glides from the 84-91's can be used. Just have to mod the mounting holes.
And the flat stock too.
E
maynards_ek
10
07-24-2007 08:17 PM
Kamikaze
03-17-2007 06:53 AM
snapper1978
09-22-2006 10:37 AM
street95civic
07-22-2006 12:02 AM
c for sea
23
01-02-2005 09:55 AM
Quick Reply: 1977 CVCC seats?
