Looking to sell my 99 accord
i can either part it out or sell the car as is . The car runs well at 340 whp just had a compression test done and everything runs well. I’m looking for 11,500 for the whole car or make offers on the parts .
MFACTORY HELICAL LSD H/F SERIES LSD-H22 Cp 77mm forged pistons with rods and thrust washers etc. Full port and polish head ,glass bead clean engine and tranny. New stage 3 400 f/lbs clutch and aluminum flywheel. briancrower cam gears and type s f20b camshafts i can get degrees if you need. All work done by haute ag , autodream , and dennis machine shop. NGK SPARK PLUG - LASER PLATINUM ( SET OF 4) NGK SPARK PLUG WIRE SET "BLUES" H22A INNOVATIVE STEEL CONVERSION ENGINE MOUNT KIT H-SERIES MANUAL Bushing Stiffness 75A INJECTOR DYNAMICS 1000CC FUEL INJECTORS D/B/H-SERIES K-TUNED INLINE FUEL FILTER Filter Size 6AN Fuel Filter RADIUM FUEL PULSE DAMPER Options FPD-R, 3/8 NPT AEM UNIVERSAL BLACK ADJUSTABLE FUEL PRESSURE REGULATOR BLACKWORKS RACING FUEL RAIL WITH 8AN K-SERIES FOR HONDA PRELUDE 1997-2001 BB6 MEGAN RACING RACE SPEC HONDA ACCORD 98-02 (4CYL MODELS ONLY) FRONT UPPER STRUT BAR SUPERTECH BLACK NITRIDED VALVE SET H22A Exhaust Valves Inconel 1mm Oversized Head Intake Valves 1mm Oversized Head SUPERTECH VALVE GUIDE SET EXHAUST BRONZE B/C/D/H-SERIES Engine 4 Cylinder SUPERTECH VALVE GUIDE SET INTAKE BRONZE B/C/D/H-SERIES Engine 4 Cylinder SUPERTECH VALVE STEM SEAL SET B/C/D/H-SERIES Number of Cylinders 4 Cylinder Engine GREDDY TYPE FV UNIVERSAL BOV - FLOATING DESIGN ARP MAIN STUD KIT 2BOLT MAIN H22/H23 SKUNK2 H-SERIES VTEC PRO SERIES INTAKE MANIFOLD ARP HEAD STUD KIT H22A4 TIAL MV-R EXTERNAL WASTEGATE V-BANDED 44MM COMETIC HONDA PRELUDE 87MM 97-UP .030 INCH MLS H22-A4 HEAD GASKET SKUNK2 THERMAL INTAKE MANIFOLD GASKET (H22) FullRace h22 turbo manifold and 44mm vband wastegate 2000$ just for this lol borg warner sxe300 turbo cant remember a/r mishimoto half rad and 12" high output fan. Custom 3 " exhaust with borla race spec muffler Custom 3" i/c piping with large intercooler Link Black Extreme Ecu True Heart 4" adjustable coilovers 215 45r19 high speed tires with rims |
