Thicker fluid in a viscous coupler for more equal torque split
I know that most of the time the rear wheels aren’t getting much power until the fronts start to slip then it sends more power to the rear but if you put a thicker fluid in the viscous coupler would you have more power going to the rear all the time? I’d like my civic to have more power going to the rear wheels to help with launches and cornering. I don’t necessarily want a 50/50 torque split unless I need it when the fronts are slipping but maybe like a 70/30 all the time?
Re: Thicker fluid in a viscous coupler for more equal torque split
The tighter you get the VC the closer to 4x4 you get and less AWD.
Thicker fluid will transfer more torque before the VC gets into hump. But it will also slip less when needed, like when cornering. I find the VC based AWD to cause a lot of understeer that immediately goes away when disconnecting the rear drive. A tighter VC is going to make the understeer even worse. |
Originally Posted by Ryanthegreat1
(Post 52558452)
It is AWD already, just has a limited amount of torque that can be transferred.
Thicker fluid will probably transfer more torque but it has the downside of not slipping when needed. If you are in the dry on hot slicks you can probably go pretty tight on the VC. If you are in the wet on meh street tires then you don't want the VC so tight. |
(Post 52558461)
Yes but there are down sides. Just the nature of the VC setup.
If it is an old original RT4WD wagon VC is is probably long past due for a service and not transferring torque as it should. Rebuild it to factory specs and see if that gets you what you are looking for. |
(Post 52558465)
Rebuild is new seals and fluid.
The plates really don't wear unless they are used in hump mode. In hump the plates touch each other and wear away. Is your VC tight enough to pass the stall test? All 4 wheels in the air, 1st gear let the clutch out and idle so all 4 are spinning. Then pull the parking brake. Engine should stall. |
(Post 52558467)
Yeah your VC is not working right. That test is from the factory service manual.
(Post 52558471)
| All times are GMT -8. The time now is 11:21 PM. |
