Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   AWD Conversion Forum (https://honda-tech.com/forums/awd-conversion-forum-171/)
-   -   hypothetical regaurding wagovan diff (https://honda-tech.com/forums/awd-conversion-forum-171/hypothetical-regaurding-wagovan-diff-3375107/)
beefystud Apr 17, 2024 03:20 PM
hypothetical question: what would happen if you had the crv k20 transmission connected to a wagovan 4wd diff with a strait custom drive shaft drive shaft , no viscous coupler , would the diff be engaged at all times ? or would the whole drive chain just explode ?
Ryanthegreat1 Apr 18, 2024 06:32 AM
Re: hypothetical regaurding wagovan diff
Correct, you will have binding in that configuration leading to the finding of the weak link. Probably the transfer case bolted to the transmission.
You need something in the system to allow the front and rear axles to operate at different speeds.
