wire horn to honk with alarm.....diagram inside... i searched and tried examples with no luck
#26
Re: wire horn to honk with alarm.....diagram inside... i searched and tried examples with no luck (c
The bar should point to which ever side is tied to +12V.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">ok great both ways of hooking up the relay worked like a charm. i was taping into the wrong the wire.</TD></TR></TABLE> I kinda figured you were, this is why I always try to get someone to do something really basic first.
Glad it worked for ya.
#27
ok and do i just solder it to the prong on the relay? or to the clip on the wire?
#28
Are you using connectors? Either location will work its up to you to decide which way best suits your needs. If it were me I would use a plug for the relay. I would connect the diode on the plug. This way when the relay dies you can just swap it out.
#29
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme »</TD></TR><TR><TD CLASS="quote">Are you using connectors? Either location will work its up to you to decide which way best suits your needs. If it were me I would use a plug for the relay. I would connect the diode on the plug. This way when the relay dies you can just swap it out.</TD></TR></TABLE>
I 2nd that. Relay's have a typical life of something like 10,000 switchs or something like that.
MantisX
Audio / Security / Video
08-27-2009 03:44 PM
