Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Audio / Security / Video (https://honda-tech.com/forums/audio-security-video-27/)
-   -   Why does keyless entry need to connect to the ACC wire? (https://honda-tech.com/forums/audio-security-video-27/why-does-keyless-entry-need-connect-acc-wire-3369199/)
integra-tor Apr 11, 2023 11:27 PM
The diagram of the keyless unit I have installed shows that it should be connected to the ACC wire. Please see below.
Anyone know the purpose of that connection since the unit already has constant power via the +12v connector?
https://cimg9.ibsrv.net/gimg/honda-t...1ff84e40e6.jpg
NVturbo Apr 20, 2023 06:56 PM
Re: Why does keyless entry need to connect to the ACC wire?
the alarm module requires +12VDC ignition/ACC power for it to work properly. Just about all car alarms require that power source.
integra-tor Apr 22, 2023 06:28 AM
Understood that it may be needed for proper operation, but my question is why that should be the case when the unit is already connected to constant 12VDC... BTW, I have connected this particular unit without the ACC connection and it is working just fine.
In a car alarm system, I can see the ACC being useful because it could be used to prevent you from turning on the alarm when the car is ON. But what is the purpose of this in a simple (non-alarm) keyless entry system? To prevent from locking/unlocking the doors when the ignition is ON? That is a bit non-sensical.
NVturbo Apr 30, 2023 04:17 PM
ACC/ignition or switched 12VDC power turns on/off certain features of the system (alarm or keyless). On the control board, it requires it. On Hondas/Acuras, finding the appropriate wires is super easy.
