removing radio pins from OEM radio conncetor
Old 03-30-2005, 11:31 AM
riceboy's Avatar
Default removing radio pins from OEM radio conncetor
I have never done this before, I did search of course, maybe I just searched using the wrong terms, cause I know this has to be on this site, I cant be the forst to ask this question.
the little silver pins that hold the wires in, how do I remove these things?
Old 03-30-2005, 12:32 PM
B18C_EJ8's Avatar
I know on the Metra & Scosche harnesses (for decks and such), they'll just pull right out (some easier than others). Otherwise, there's usually a locking tab that you have to press in with a pick tool and the terminal should slide right out...
Old 03-30-2005, 07:23 PM
fcm
Old Fart
fcm's Avatar
Default Re: removing radio pins from OEM radio conncetor (riceboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceboy &raquo;</TD></TR><TR><TD CLASS="quote">I have never done this before, I did search of course, maybe I just searched using the wrong terms, cause I know this has to be on this site, I cant be the forst to ask this question.
the little silver pins that hold the wires in, how do I remove these things?</TD></TR></TABLE>My question would be WHY do you need to remove them? and as B18C_EJ8 said.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I know on the Metra & Scosche harnesses (for decks and such), they'll just pull right out (some easier than others). Otherwise, there's usually a locking tab that you have to press in with a pick tool and the terminal should slide right out...</TD></TR></TABLE> there is a retainer on the metal pin, [metal tab folded out so it sits behind part of the plastic plug] or a [plastic tab on the plug that folds into part of the metal pin] eather way the tab has to be in, [on the pin] or out [ on the plastic plug] so the pin can slid out, if you look close, it's not hard to see what you have to do, but you will need a pick or something small to get in there, and be carefull you don't damage anything, [very easy to do] 94
Killtodie
Honda Civic (2001 - 2005)
01-10-2007 06:44 AM
johnclaunch
05-10-2006 12:15 AM
escape2me
04-15-2005 10:31 PM
SpoonSpecR
09-17-2003 02:07 PM
nsxmugen
06-01-2003 06:43 PM
Quick Reply: removing radio pins from OEM radio conncetor
