Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Audio / Security / Video (https://honda-tech.com/forums/audio-security-video-27/)
-   -   Viper Alarm HELP (https://honda-tech.com/forums/audio-security-video-27/viper-alarm-help-1822426/)
grizzy225 Nov 27, 2006 07:53 PM
Viper Alarm HELP
Have had no problems with my alarm until this morning. Not sure if it was a button i pressed or what. Model EZSDEI478. Only a couple things I noticed were different. Theres no more alarm sound. The lights still blink like they should but theres no sound. And the blue LED stays a solid blue instead of blinking. Mabye its in valet mode and i dont know how to take it out? I checked all the fuses under the dash and all were ok. The knock sensor was in working order. When i locked and unlock the car it works on the remote and i hear the relay clicking over.
Any Ideas appreciated!
Thanks!
-Steve
wrx-killer-Sti-eater Nov 27, 2006 08:28 PM
Re: Viper Alarm HELP (grizzy225)
Its in valet mode. open a door. passenger so your not in the street. Press lock,unlock,lock,unlock,lock. This should cure your problem. Bigger problem is that if you can look right under the dash and check the fuse on the alarm. Your alarm is in no shape to protect your car. https://honda-tech.com/forums/images/smilies/emthup.gif
P a r i s h Nov 28, 2006 04:56 AM
Re: Viper Alarm HELP (wrx-killer-Sti eater)
Ive been having a similar problem with my viper alarm as well.The screen dosent acknowledge when the car is locked or unlocked and the auto start will run for like 4 seconds then shut off and keep trying to turn over.Ive thrown codes at it with the doo open and it will be back to normal, but soon after it will start to do it again.Does anyone know if its my pager or wiring or....help.
grizzy225 Nov 28, 2006 12:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">Its in valet mode. open a door. passenger so your not in the street. Press lock,unlock,lock,unlock,lock</TD></TR></TABLE>
Yess!!!! Worked! Open up door and tried the way you did.. didnt work.. so i got pissed and kept pressing them back n forth and the remote went beep beep beep and now it work!!! yessss
wrx-killer-Sti-eater Nov 28, 2006 12:39 PM
Re: (grizzy225)
opps my bad. It starts with the unlock first. Glad you got it. https://honda-tech.com/forums/images/smilies/emthup.gif
FATKID87 Dec 8, 2006 07:31 AM
Viper Alarm HELP
i need help too my problem is similar and i dno't know what model it is but i have a viper alarm and one day it stoped beepin when i pushed the lock button on the alarm... i don't think its settin either cause i locked my doors with the button and then went around the passenger side and unlocked that door with the key and opened it and the alarm didn't go off... so i don't know what happend could some plz help!
wrx-killer-Sti-eater Dec 8, 2006 09:38 AM
Re: Viper Alarm HELP (FATKID87)
what is your led doing? Does it flash or does it blink when you try to arm it?
FATKID87 Dec 8, 2006 11:26 AM
it blinks. i have an old school remote (haven't upgraded yet) so all i have is the one green led and it blinks like it always has
*edit*
i fixed it!! i had found the valet button and pressed it by accident!
Modified by FATKID87 at 3:35 PM 12/11/2006
just_dung Dec 9, 2006 12:39 PM
my problem is kind of the same, my keyless entry works, panic button works, but when i arm the car the L.E.D lights doesnt go on at all? help!
Maluko Jan 25, 2010 11:53 AM
my viper 350hv alarm is doing this gay shit...i tried unlock, lock method but i still dont hear the chirp. if anyone can help out.
the dumb led stays on 24/7.
Maluko Jan 25, 2010 07:11 PM
i got it to work now. who ever runs into this problem you need to take it off of valet mode.----> press LOCK/UNLOCK button once, followed by the AUX button, then LOCK/UNLOCK. give it a sec or two and there it is back to normal.
AyoSmokie Mar 4, 2012 06:18 PM
Thanks to you guys I fixed my alarm :D
wrx-killer-Sti-eater Mar 4, 2012 06:22 PM
Lets let the old threads have there rip status. Lets make new.
pmcolman Dec 5, 2012 07:51 AM
For me as well ... I had the same problem and it is now solved ... thank you all! :-)
Paul
