Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Audio / Security / Video (https://honda-tech.com/forums/audio-security-video-27/)
-   -   Stereo in dome light out????? (https://honda-tech.com/forums/audio-security-video-27/stereo-dome-light-out-2700687/)
EKing Dec 23, 2009 10:25 PM
So I just finished putting an Alpine Cd player in my 98 Civic ex and everything works properly except for the dome light. The light will turn on when i switch it to on but it wont turn on when i open the door and the switch is turned to the door spot (whatever that's called.) Does anybody know what could be wrong with it? thanks
NOFX Dec 24, 2009 12:08 AM
Re: Stereo in dome light out?????
You removed your stock radio in a '96-'98 Civic, which makes the dome light stop working with the door and also makes keyless (if equipped) stop working.
The keyless is tied into a unit that's part of the radio on these cars.
For the dome light there's supposed to be a way to wire it so it will work.
fcm Dec 24, 2009 05:42 AM
If all your worried about is the dome light, [no key-less or have an aftermarket key-less like alarm or remote start] then you can get a jumper plug... http://www.scosche.com/products/sfID.../productID/597 or just jump/connect together the light green/red and the light green black in the key-less harness, [other plug plugged into stock radio].
If you no longer have key-less entry, you either have to add an aftermarket one or you need to keep the stock radio in the car, there is also a harness for that... http://www.scosche.com/products/sfID.../productID/301
http://www.installdr.com/InstallDocs...PDF/466013.pdf
An aftermarket alarm is the way to go. 94
