Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Audio / Security / Video (https://honda-tech.com/forums/audio-security-video-27/)
-   -   Static Noise (https://honda-tech.com/forums/audio-security-video-27/static-noise-198328/)
Unjockable May 31, 2002 05:09 PM
Static Noise
I just recently noticed a static noise when I listen to music. It's there when the volume is low and I can hear it when I listen to music without a lot of bass. Anyone know how I can stop the staic noise?
[Modified by Unjockable, 2:11 AM 6/1/2002]
sparq May 31, 2002 08:01 PM
Re: Static Noise (Unjockable)
Can you give us more info? What does your system consist of as far as products... all OEM or what? That might help us figure out the problem as it can be a million and one differant things at this point.
turbocoupe May 31, 2002 08:23 PM
Re: Static Noise (Teken)
$20 says your rca's and power wire are running on the same side of the car. . .that is if you are running amps.
Unjockable May 31, 2002 11:06 PM
Q1: Is noise consistent with volume increase / decrease?
Q2: Does the noise change in pitch with increased engine RPM??
Q3: Can you hear this noise when the engine is off?
Q4: Does the noise make a poping noise?
Q5: When you select from CD to Tuner modes does the sound appear when the button is depressed?
Q6: What changes have occured in your system / automobile?
Answer all those Q's honestly after you *really* test each one... Then you will have your answer...
Regards
Teken
1. The noise is there when the volume is low. It's still there when the volume is high but you can't hear it as much since the music is louder.
2. No
3. Yes
4. No
5. No
6. I just recently got a Alpine 7894. I'm running 2 amps and a sub. A shitty amp for my speakers and a kenwood amp for my JL sub.
Unjockable May 31, 2002 11:08 PM
Yeah, I'm running RCA wires on the same side of the car. It's not a wissing sound, it's static.
