Shock Sensor mounting point
Where do you guys mount your shock sensor? I know some of the members said mount it on the steering column but do you just screw it directly to the column or zip tie it?
Re: Shock Sensor mounting point (LostGsr)
use zip ties! you will cause big problems if you try to screw it to the column.
| All times are GMT -8. The time now is 11:14 PM. |
