Was the salesperson right? Amplifier question.
So I went to a local big name retailer to purchase a 2 x 10" subwoofer setup with amplifier. I decided on the Polk MM1040's since I liked their sound and price point. In terms of amplifiers I was aiming towards the Hifonics amp but the salesperson recommended Crunch amp. I was under the impression that class D amps were usually the best for subwoofers because of their efficiency producing power. However he told that this the Crunch amp would be better choice since it puts out more power and is also an A/B amp so it will have less distortion. I just wanted to get a second opinion, I've had bad experiences with this big retailers in the past so I took his suggestion with a grain of salt.
Polk Audio AA3104-A MM1040 10-Inch Subwoofer 4 OHMS, 350W RMS, 700W PEAK. MM1040 Car Subwoofer from Polk Audio Crunch Ground Pounder GPV2000.1 Maxx Watt Power A/B Class Mono Amplifier 1 x 500 W at 4 Ohms, 1 x 1000 W at 2 Ohms, 1 x 2000 W at 1 Ohm Maxx Power Amazon.com: Crunch Ground Pounder GPV2000.1 Maxx Watt Power A/B Class Mono Amplifier (Silver): Electronics Hifonics HFi1000 Hfi Series D-Class Mono Amplifier 1 x 475W @ 4 OHMS, 1 x 750W @ 2 OHMS, 1 x 1000W @ 1 OHM Amazon.com: Hifonics HFi1000 Hfi Series D-Class Mono Amplifier 1 x 475 @ 4 OHMS, 1 x 750 @ 2 OHMS, 1 x 1000 @ 1 OHM: Electronics |
Re: Was the salesperson right? Amplifier question.
My lil cousin is using crunch amp in his civic... its not that great. Maybe he has a cheaper model? who knows. I would recommend MTX...
well based on the specs
subs are 350W rms (single 4 ohm voice coil) each. So 350x2 (paralleled coils= 750w @ 2 OHM) the amp is 750W rms @ 2 OHM So basically its actually a pretty good match for each other. |
I am not sure what he is talking about "less distortion" with a class AB. Class D would have the least I would think given that it's either always on or always off. AB runs linear which would be very inefficient for a sub system I would think
Crunch amps don't even do their rated power and they're noisy as hell.
There's a reason they cost pennies. did u get single 4 ohm subs or dual 4 ohm? |
I believe that Crunch test their products on a 14v test bed. Many companies do this and that's why cheap amps can give big power numbers. I would go with a mono channel amp. Kenwood make great amps for the price.
first, Hifonics and Crunch are made by the same company and the guy was right, D class is a more dirty amp then an A/B class, that's how they gain the effeciancy, just look at the THD numbers.
what other amps do they have?
Originally Posted by mhart
(Post 44672942)
(Post 44672942)
Originally Posted by JonnyT
(Post 44680915)
I have yet to notice any sort of distortion in a class D amp that is set up properly. At the frequencies that sub pick up and the power they need a class D amp is the way to go. Just listen to a well set up system that uses a class D amp and tell me if you can tell any sort of difference if you were to use a class A/B
Class D amps are more noisy. The important thing is to understand where they are more noisy. Class D amps apply a switching supply directly to the output. That is why they are so efficient. They then run that output through a filter to remove the high frequency switching noise. What you are left with is a relatively clean low frequency output. This is primarily why Class D amplifiers are subwoofer only amps. Although high end class D amps are also used for higher frequencies. Your subwoofer will use the most power so it makes more sense to use class D on subs and class A or AB on mids and tweets. As far as muddy bass hogwash.
I tried to make that as simple of an explanation as possible and glossed over a lot. In summary I wouldn't hesitate to buy a class D amplifier for my subwoofer. Your electrical system will thank you for it. |
