Repairing / Re-Foaming JL 12w0's
I have a pair of 12w0's that I bought in 1998 that are finally in need of some TLC.
The surround on one has deteriorated substantially, and has separated from the basket in a couple of places, with the biggest "hole" being about 4 inches long. This is causing some rubbing of the coil, but if I put some pressure on the cone in the direction of the hole in the foam, the rubbing ceases. The other has some rips in the surround, but only a faint rub can be heard..
I'm fairly confident that I can refoam these speakers using a kit like this: http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT.
My question is if I can make the rubbing stop by "re-centering" the cone with my hand, in theory, a refoam should resolve the problem permanently, correct?
Re: Repairing / Re-Foaming JL 12w0's
I do see they do make this statement
It can be very difficult to refoam a speaker without removing the dust cap and inserting the plastic shims. The plastic shims are used to center the voice coil and cone assembly while the speaker is being refoamed. If you do not use the plastic shims, the voice coil may be off center and it may lead to the voice coil rubbing.
Sounds as though they have you covered with te shims. Just don't try to do it without the shims. I tear apart a cheap shaving razor the blades are very thin and flexible. They work perfect for cutting the dust covers off.
The part about the shims is why I ordered from them. Plus, it looks like they use something a bit more substantial than the elmers glue looking adhesive shipped with other kits that were cheaper. Kit should be here tomorrow.
We shall see how it turns out. I can't exactly make the one much worse... I'll do that one first and see how it goes.
Oh, and good tip about the shaver blades... I was going to try to buy the smallest & skinniest x-acto blades I could find, but that sounds like a better option, for probably under a buck.
hey can't complain, jl makes a good product. Since it is such a common sided foam surround, you maybe able to find it at partsexpress.com i know they have the "double wave" red surround for the old vega's pretty cheap.
92SleeperH23
Audio / Security / Video
07-18-2006 03:20 PM
p nut
10-09-2005 08:17 PM
corona
03-11-2004 05:09 PM
