PS2 install?
Hey im putting my old PS2 into my teg, and was wondering where the best location was, given the limited space in my car im using the old bigger version, and was thinking about putting it in the glove compartment so that i could hide it when its not in use, but i read that it wont work if its at an angle... pics would be helpful. thanks alot for your help/advice.
Re: PS2 install? (shiux)
Sorry no pix, but I have installed more then a few of them at all sorts of angles, and not run into problems, [unless car is going over very bad bumps] https://honda-tech.com/forums/images...s/emsmilep.gif 94.
so you think that if i had it in the glove compartment, which would put it at a slight angle, i wouldnt have any problem with it playing?
just wanna make sure before i start cutting up my dash. |
Re: (shiux)
Just plug it in at home, put something in, start playing and put the PS2 on the angle it would have to be in the car, and see how it works, then just to be sure add some "simulated" potholes and railway tracks, to see how much it would take to mess it up, I am playing a DVD in mine now, [in the house] and it is up side down.
You can also do the same thing in your car, install and wire everything but don't mount the PS2, just remove the glove box and set the PS2 about where it will go and try it. https://honda-tech.com/forums/images...s/emsmilep.gif 94 |
| All times are GMT -8. The time now is 03:29 AM. |
