No sound on driver side
I installed an aftermarket HU in my 97 Civic while retaining the stock HU so I can continue to use my keyless entry system. I used a wiring harness for the new HU installation. Everything was working fine until about a week ago when my driver side speaker and tweater stopped working.
I ruled out anything wrong with the speakers by switching them out with the passenger side speakers and confirming that they still worked. I pulled the HU to check for any pinched wiring, but couldn't find anything. Can anyone help with any other suggestions?
I was just going to get new speakers, but I dont' think that would help. I think it might be a wiring problem or maybe something wrong with a fuse. What and where are the fuses that I should be checking?
Old Fart
Re: No sound on driver side (SD619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD619 »</TD></TR><TR><TD CLASS="quote">I installed an aftermarket HU in my 97 Civic while retaining the stock HU so I can continue to use my keyless entry system. I used a wiring harness for the new HU installation. Everything was working fine until about a week ago when my driver side speaker and tweater stopped working.
I was just going to get new speakers, but I dont' think that would help. I think it might be a wiring problem or maybe something wrong with a fuse. What and where are the fuses that I should be checking?</TD></TR></TABLE> Try plugging the stock Hu back in, ans see if that works, if it does, then you may have a problem with the "T- harness" or the connections or the aftermarket HU, if with the stock HU the speaker stilldoesn't work then you have a problem with the speaker wire, [in the doorjamb maybe, also if you want to get rid of the stock HU, just install an alarm and hook up the doorlocks. 94
patrickvertigo
Audio / Security / Video
04-11-2011 06:37 AM
BrandonClaps
06-27-2003 01:31 PM
