Need Help Alarm Viper 5706V 94 Acura integra
Hi i need Help installing My alarm
i sorted The alarm its a pager alarm. my old viper alarm came with my car is no good i removed all of that. i am not going to use The Remote Start if necessary but need my alarm working. its a 5speed so i dont need the remote start.
what is the best location for the motion sensors. i have power locks and power windows. also i already mounted the antenna as well as the siren.
whats the good power to hook up etc for the module?
O.G. triple O.G.
Re: Need Help Alarm Viper 5706V 94 Acura integra
you mean SHOCK SENSOR? Or do you actually have a proximity sensor??
Shock sensor...anywhere but it has to be ziptied to wire instead of actually mounting it.
Proximity sensor....center of the car, likely under the center console where the arm rest is. Make sure to not leave your cell phone in there while the car is armed. RF signals on your phone will trigger the sensor to go off.
oh ok i will mount that sensor that came with the kit near the center part should i sticky tape inside frame?
not in plastic.
ok i need help with the wiring
6pin connector
got power,ground, siren mounted
#4what is parking light isolation wire #87 n/c of onboard relay
#5parking light output white on harness go to
#6 orange wires go?
O.G. triple O.G.
not in plastic.
That's a shock sensor. You ziptie it to a wire loom. It's not meant to be mounted.
not used
red/black wire (dimmer dial switch)
#6 orange wires go?
not used (that becomes a ground wire, when armed)
not in plastic.
not used
#6 orange wires go?
[QUOTE=NVturbo;51877066]
oh ok thanks ive mounted those wires and now need help where the other wires need to go?
Door Lock 3-pin connecote
#1 blue -500ma unlock output
#2 green -500mA Lock output
also the Aux/Shutdown/TriggerHarness 24-Pin Con.
what wires do these go and nexessary for my install thanks
#9 gray hood pin input
ive installed my hood pin so is that one the button one? and the other is ground?
#12 violet/White. tac. input
#13 black/white. (-) brake E-Brake input
#15 Green ( -)door input?
#18 Violet (+) door input?
where do these wires go?
are there more wires i need to put?
thanks
#1 Blue door unlock goes to the black w red stripe in the driver kick panel.
#2 Green door lock goes to the black w/ white stripe. Also in the driver side kick panel. Be sure to test using a multimeter. The are a negative trigger (-)
#9 hood pin input
When you mount the hood pin switch I recommend mounting it on the core support. This will give you the ground (-) signal when the hood is opened. Using the spade terminal or soldering the wire to the hood pin switch you will then run the wire into the car through one of the grommet. Use wire loom. Also be sure to sand off some of the paint when you mount the hood pin switch.
#12 & #13 aren't used. Those are for the remote start feature which you said you are not using.
#15 Green door trigger input goes to light green w/ red stripe in the drivers side kick panel. Be sure to test with a multimeter. It is a negative (-) signal when any of the door are opened.
#18 is not used
#9 hood pin input
#18 is not used
bump anyone know? my car been sitting for a long time i wana get it done no one helping me. i got all power locks alarm hooked up the hood pin and the door switch.
my next im confuse the dam blue light blinks armed and disarmed. wtf also i wanted to put the ten pin remote start but dont know where the wires to go?
Instead of using the hood switch that comes with the kit try a used oem switch from a bmw or some other car. I don't like the idea of drilling a hole and having it rust, especially if it is in a rain channel in the truck or hood. And the ones that I've seen in kits are so cheap they look like they will fail. I like those angle activated ones. Also you can get your alarm up and running for now with just a couples wires. Then add more later. The biggest problem on an integra with power locks is someone pressing the unlock button from the outside of the car. So read about fixing that. Then try to add time to the thief's break in. First he/she will pull some fuses or any extra wires or boxes under the drivers side dash area. Then pull the siren out if they can find it under the hood. (try inside fender) So add some dummy wires. Run different 12v+ than one would expect. Make it so you would have to take stuff apart to find the main control box, and make it hard to just follow the wires from the valet switch or the led light.
cambodia got civics too
Audio / Security / Video
11-05-2005 05:21 PM
