help on 98 civic ex alarm instal
Old 02-14-2008, 07:22 PM
turbo-2nr's Avatar
Default help on 98 civic ex alarm instal
im going to instal a alarm on my 98 civic ex i was just wondering if all the wires or most of them can be located were the factory keyless entry/security box is if any one has a pin out or diagram of thse wires it would help thanks
Old 02-15-2008, 06:04 AM
i my honda
Global Mod
White Smoke's Avatar
Default Re: help on 98 civic ex alarm instal (turbo-2nr)
Yes most of the wires are there. This has been covered!
https://honda-tech.com/zerothread/1794938
http://www.the12volt.com/insta....html
Old 02-15-2008, 06:32 AM
fcm
Old Fart
fcm's Avatar
No, you will not find much more then the door lock leads there.
http://64.85.6.121/diagrams/pr...eID=3 94
Old 02-15-2008, 06:48 AM
i my honda
Global Mod
Default Re: help on 98 civic ex alarm instal (fcm)
If his car came with the security option he will find horn, doors, dome light, trunk and ign all behind the radio. I think the parking lights are back there too but can't remember. It's a green connector. I know on the 99-00 the parking light wire is there as well but can't remember about the 96-98 model as it's way different. Id say that classifies as "most" wouldn't you?
Also, my wire diagram is better (seeing as yours has no mention of the stock keyless connector behind the radio)
Old 02-15-2008, 02:17 PM
fcm
Old Fart
fcm's Avatar
Default Re: help on 98 civic ex alarm instal (White Smoke)
I checked Wire Magic at work and it also gives door locks, trunk/hatch and door pin, but nothing else. 94
Old 02-16-2008, 01:56 PM
i my honda
Global Mod
I know the horn is back there too.
Old 02-25-2008, 05:51 PM
turbo-2nr's Avatar
thanks, iv got every thing installed using bolth of you charts im impressed withe my self since this is my first alarm and withe sodering and every thing it only took a bout 2 hours the only thing left is parking lights i cant seem to find them by the kick panle or go n in to the fuse box. is there not one behind the radio like the rest ? it seems like there would be one since they flashed and the horn honked with the keyless entry ,ps when my alarm goes off the led blinks after i turn it back off to let me know it was tripped only thing is it dont reset so every time i unlock it the remote beeps and the light stays on wile i drive any imput thanks, o the alarm is a viper zz1xv
Modified by turbo-2nr at 7:06 PM 2/25/2008
Old 02-26-2008, 05:26 AM
fcm
Old Fart
fcm's Avatar
Default Re: (turbo-2nr)
You can use the park light free pin on the under dash fuse box. 94
Old 02-26-2008, 02:24 PM
i my honda
Global Mod
Do you have the alarm hooked up to the yellow ignition wire? This usually resets the system, I thought.
Old 02-26-2008, 03:07 PM
turbo-2nr's Avatar
its hoked up to the whight ign. wire l.ike the wire charts say to . do you know were the parking light wires behind the dash are?the red is what i have hooked up and the blue i was told i dont need unless imusing remote start or runing it with the stock keyless entry. Is there ant thing els i need to hook up if so were dose it go
Modified by turbo-2nr at 4:19 PM 2/26/2008
Old 02-26-2008, 04:52 PM
fcm
Old Fart
fcm's Avatar
As I said, there is a park light free pin on the under dash fuse box.
If you did not install the remote start relay pack, [heavy gauge wires] the alarm has no ign. input.
If you are not installing the remote start, use the yellow lead in the ribbon harness that goes to the relay pack, all you need on the ribbon wire plug is the yellow lead, de-pin the rest, connect it to your cars ign. lead, [black/yellow]. 94
Modified by fcm at 5:26 PM 3/6/2008
Old 02-26-2008, 06:38 PM
turbo-2nr's Avatar
do you meen tap in to the white(#2) box as shown here
Old 02-27-2008, 05:41 AM
fcm
Old Fart
fcm's Avatar
Yes, it is the park light free pin, it can be used as an output or an input, in fact it can be used as an input, [from alarms light flash output] and an output, [to lights in extra gauges] at the same time. 94
Old 02-27-2008, 05:48 PM
turbo-2nr's Avatar
just making sure becausae that is were my gauges are wired in thanks
Old 02-28-2008, 03:26 PM
turbo-2nr's Avatar
is there any were els i could hook the pink wire to son i dont have to take apart my stering colom agin
Old 03-03-2008, 05:14 AM
i my honda
Global Mod
Not really, it should be hooked to the yellow or black yellow wire.
Old 03-03-2008, 05:46 PM
fcm
Old Fart
fcm's Avatar
You can make the connection to the ign. lead at the other end of the ign. switch harness, no need to take the column trim off, " i dont have to take apart my stering colom agin" or you can find any "true" ign. source, [hot in run and start] and make the connection there, but only if you are using the yellow in the ribbon harness, [remote start not being installed]. 94
Modified by fcm at 5:28 PM 3/6/2008
Old 03-06-2008, 02:59 PM
turbo-2nr's Avatar
would the 12v acc off of the fuse box be a "true" ign source? if not what would be because i hooked up the pink wire to it and it does not reset the system
Old 03-06-2008, 03:25 PM
i my honda
Global Mod
No acc is acc not ign, it drops power when you "start" the car.
Old 03-06-2008, 04:33 PM
fcm
Old Fart
fcm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-2nr &raquo;</TD></TR><TR><TD CLASS="quote">would the 12v acc off of the fuse box be a "true" ign source? if not what would be because i hooked up the pink wire to it and it does not reset the system </TD></TR></TABLE> Sorry, my dumb mistake, it is the yellow lead in the ribbon harness, not the pink lead. 94
PS If you connect the yellow lead to an acc. it will not function properly.
nightscream
08-14-2011 10:44 AM
rx7_dude2003
Audio / Security / Video
03-28-2010 04:56 PM
John3x714
10-23-2008 05:42 PM
98greensi
04-07-2008 05:51 AM
antiJDM
07-05-2004 10:40 AM
Quick Reply: help on 98 civic ex alarm instal
