Kill Switch Question... need a relay?
I'm planning to install an ignition kill and a fuel pump kill. I've seen a couple of posts about this, and some have recommend using a relay, while others say to just use a switch.
Is a relay necessary or will a swith suffice? What would the current rating on the switch need to be? Also, will a closed relay drain a battery if you park for a [long] while? thanks |
Re: Kill Switch Question... need a relay? (Christine)
Heres a link in the audio/security forum. A lot of people have installed this in thieir cars. Good Luck!~!
http://www.honda-tech.net/zerothread?id=42336 **hint**hint** ^~~~~~ use the search functions!~! http://images.zeroforum.com/smile/emsmileo.gif |
