Remote start DEI 500M, Pink/White-second accessory?
Using Clifford 50.5x brain, 500m Xcrs relay pack for remote start. What would I hook this pink/white wire to? manual says its for second accessory/second ignition.
So far I've hooked:
Two reds(relay side) ->(to) white (car side)
Orange -> white/black
Pink -> black/yellow
Green -> yellow(key side) (had cut yellow instead of tapping onto)
Purple -> yellow(starter side) '' '' ''
Correct me if I'm wrong on any of the above!!
Been doing a little research and now I'm wondering if if should have connected the green and purple to the black/white instead.
Pink/white -> ???
Red/white -> ??? is this another +12v constant?
FYI installing in 96 civic ex
So far I've hooked:
Pink/white -> ???
Re: Remote start DEI 500M, Pink/White-second accessory?
its there because some vehicles require 2nd ign or 2nd acc to function while started
(some even have 3 ). If the tech info for your car says you don't need it just isolate it.
Now I already have two reds for constant +12V. What is the red/white wire for?
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Connect the red and white to power too. Discard the pink/white. Also yellow is not starter on your car. Its black with a white stripe.
I have the same system and i need the remote but dont know what remote i need to get...can anyone let me know the name of the remote?
