Amp wiring turn on led
Old 06-17-2002, 09:29 AM
PearlWhiteAccord's Avatar
Default Amp wiring turn on led
Hi,
wanna know which wire am I suppose to wire the turn on wire to on the car stereo..is it the Accessories wire?
Old 06-17-2002, 12:35 PM
Default Re: Amp wiring turn on led (PEARLWHITEACCORD)
anyone????????????????
Old 06-17-2002, 01:00 PM
schwinn's Avatar
Sometimes it is called the power antena lead(spelling =/) usually is a blue wire coming off your deck.
Schwinn
Old 06-17-2002, 02:06 PM
jdm civic's Avatar
Default Re: Amp wiring turn on led (schwinn)
blue wire,sometimes has a white stripe
Old 06-17-2002, 02:12 PM
o_Rage_o's Avatar
Default Re: Amp wiring turn on led (jdm civic)
The wire you want to use should show a +12v when the key is in the accessory (on) position and 0v when it's out.
This wire is usually the blue/white wire (like the others said) , can also be the acessory wire. It's best to just take a meter and double check. You can use as small a guage as you want for the wire as well, becuase it's a low current signal.
Good Luck!
-Rage
Old 06-17-2002, 02:45 PM
Default Re: Amp wiring turn on led (o_Rage_o)
i know that the power antenna usually turns on only when u listen to radio, but i listen to mp3 cd on mine as well, will that turn on the amp???
i found the accesories wire, should i use that one instead???
also the guy replaced the power antenna to a rubbber one, so there is no power antenna...
Old 06-17-2002, 03:22 PM
o_Rage_o's Avatar
the acessory wire was prob hooked up to your power ant wire before anyways. if you hook it up, before putting the deck back in the dash, turn on the key and double check if it turns on the amp.
the honda factory decks and some others i know keep the ant up even if your listening to cd
coles notes: accessory should be fine
-Rage
Old 06-17-2002, 05:43 PM
GSRaCeRbOI's Avatar
since you have MP3 capability .. Im assuming you have an aftermarket deck and that it has a remote turn on lead for the amps.. on my Alpine unit its blue/white.. could be blue on other decks... you can hook it up to the accessory wire.. just use a multimeter and test which wire has voltage when you turn your key to on.. and cuts off power when your key is off...
Old 06-18-2002, 05:17 AM
Default Re: Amp wiring turn on led (GSRaCeRbOI)
thanks for the help, i will connect the turn on lead to the accessories wire since it turns on when key is on or on accessories...
Jordan8742
Audio / Security / Video
03-25-2015 09:19 AM
bopbop93030
13
05-05-2009 11:08 AM
nasports
02-14-2008 04:09 PM
IgotV-tec!
07-07-2003 04:38 PM
ptsiu
10-04-2002 11:45 PM
Quick Reply: Amp wiring turn on led
