Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Audio / Security / Video
Reload this Page >
I wanna put some sound in my car dont know where to start
Old 02-26-2010, 09:52 AM
averyvm's Avatar
Default I wanna put some sound in my car dont know where to start
Hey Im kinda new to audio world.
I wanna just throw a sub in my car and mount my mid component speakers in a fashion in which I could get the most sound out of them.
But just like everything else there seems to be a science behind everything. It seems like bolting speaker to the door using that stock plastic piece makes the car sound like crap. Ive been looking at other pictures and stuff and looks like maybe its optimum to make your own little speaker mount out of MDF wood. Dont have a saw but is it worth bying one?
averyvm is offline
Old 02-26-2010, 02:16 PM
They let me pick
mrdeadman's Avatar
Default Re: I wanna put some sound in my car dont know where to start
Step 1: Buy aftermarket hu. Clarion or alpine will be good.
Step 2: add sub.
Step 3: upgrade speakers and amp them if you like to listen to them really loud. You WILL need to make MDF mounts for the speakers otherwise they will sound like **** (usually).
2 and 3 are pretty interchangeable. If you want more bass, add a sub, if you want louder, clearer sound add speakers first. If you have any blown speakers, I would do speakers first regardless..
mrdeadman is offline
Old 02-26-2010, 05:55 PM
wes7side5o's Avatar
To be honest if you want a nice sounding system Get an apline deck. Always loved alpine over all other decks. Then get two amps. I recommend JL audio. You can buy a 500/1 for about 220 (just got to look around) used on craigslist. Then you can get a JL 450/4 for 240 on CL as well. Then purchase a sub. You can pick from a range of subs that sound nice. Forget those frys and bestbuy subs they suk *****. Get like an eclipse titanium ($300) or JL W6 (250) W7 ($450). Then finally get some component speakers. Everybody has their own favorite so you will just look around for that. I personally loved the infinity, bostons, and the diamond audio. But I have heard some polk audio and other cheaper ones that sounded pretty clean as well. Put all those together and you will have the sound system of your deams. If you like it really loud then just get stronger amps. Like the 1000/1 JL ect... Oh forgot this is a must reguardless you must get a capacitor. Everything will sound clearer with it and your battery wont go dead and you wont get those annoying dimming of lights when bass hits. Don't get those cheap ebay ones either get the rockford capacitors then work wounders (from my own personal experience). GL with install.
wes7side5o is offline
Old 02-27-2010, 08:53 AM
www.caraudio.com price check for retail or go to the forums and look used in your area for subs HU and get ideas from the build threads.
Pottro563 is offline
Old 02-27-2010, 02:34 PM
Step 2: add sub.
get a sub before changing the stock speakers?
edzy is offline
Old 02-28-2010, 09:20 AM
fcm
Old Fart
fcm's Avatar
Need more info, although not essential a MM&Y of car will help.
The single best improvement you can make in a cars audio system is to replace the stock HU, you did not mention a new HU, is that because you already have one?
To a point I agree with edzy, [I hardly ever do] adding a sub before replacing the stock speakers will make a more dramatic diff. in sound, you will be surprised at how good stock speakers can sound when they have some decent power driving them, [aftermarket HU].
You have been misinformed, [or you misunderstood] installing aftermarket speakers to stock plastic speaker housings will not "sound like crap" it will just not sound as good as it can, even the stock speakers sound better mounted to wood then to plastic.
With that said, proper speaker installation is critical to SQ, [sound quality], no matter what the quality of the speaker is, a properly installed entry level speaker will outperform an improperly installed "top of the line" speaker, so much care and attention is needed when installing speakers.
The 4 basic rules for installing speakers...
1- Speaker must be mounted to a flat surface,. not doing so can warp basket and misalign speakers VC, [voice coil].
2- Speaker must have airtight seal between front and back of speaker for at least the diameter of the speaker out from it's edge, the best is to have a speaker in a box, very difficult in a car door so at the very least no holes for at least 6.5" from the edge of the speaker, not doing so will result in cancellation, [loss of output due to back wave of speaker interacting with the speakers front wave.
3- Mass, the more mass the speaker is mounted to the better, this has more to do with mounting speaker to a solid surface, a surface that can not move, remember..
for every action there is an equal and opposite reaction, you want, [and need] the speaker cone to move back and forth, you do not want the speaker itself moving back and forth, that would also result in cancellation.
4- Wood, a speaker mounted to wood will sound better then the same speaker mounted to just about anything else, definitely better then if mounted to sheet metal or the plastic of the stock speaker housings.
The above rules become more important the lower the frequency response of the speaker, EG; a tweeter hanging in midair will sound about the same as if it is mounted to an MDF baffle, a mid-range speaker will sound like crap hanging in midair, a sub-woofer will sound no better then the mid-range.
A few things to also keep in mind...
Wattage...
Forget about anything but RMS, [amp power] or continuous, [speaker power handling] wattage, peak/max wattage means very little.
It is better to be over-powered then under-powered, EG; if you have 75W speakers it is better to have a 100W amp then a 50W amp.
With that said, under-powering speakers does not blow speakers, driving an under-powered amps into constant clipping, [distortion] is what blows speakers.
A min. ratio of about 3:1 low-pass to high-pass should be used for good SQ, EG; if you have a set of 75W component speakers, you should have a sub with 450W of continuous power handling, 100W speaker/600W sub and so on.
Although good SQ comes from good quality product, installation has more to do with SQ then the product itself, it makes no diff. how expensive the product is, if it is improperly installed it will sound like crap.
Feel free to IM me if you have questions. 94
fcm is offline
Old 02-28-2010, 09:27 AM
mwaedow's Avatar
I have found Infinity speakers to be the best bang for the buck. The Kappa series is awesome. They're not components, so you don't absolutely need an amp with them, but they're affordable, and if you do amp them, they sound as good as any component on the market. Get a Diamond Audio 12" sub, either a D3 or a D6, and you'll be extremely happy with your bass. I would also recommend getting an audio processor to add even more customization to your system. I run a Kove Audio Aphex processor, and it really makes a difference.
mwaedow is offline
Old 07-09-2010, 06:52 AM
averyvm's Avatar
Never did say thank you for the input. Thanks. But I really like the rockford fosgate 12" P3 which is 500W rms subwoofer. Also I have a Clarion HU with some Pioneer 50W rms door speakers that are just mounted to the doors in my EG using my stock plastic speaker mounts. I want to make some MDF rings but only tool that I have is a jigg saw. Is that enough bump?
averyvm is offline
Old 07-09-2010, 11:24 AM
GhettoBizzle's Avatar
Im 100% agree with EVERYTHING that fcm Has said.
GhettoBizzle is offline
Old 07-09-2010, 01:44 PM
fcm great info for anyone.
OneFire is offline
Old 07-09-2010, 03:16 PM
Master Detailer
98civdx's Avatar
FCM nailed it.
What i did was
Headunit
then speakers kicker in front cliffdesigns in rear, i ended up switch the kickers out for infinitys, they are much better.
then added a 400watt 4 channle and ran 12 guage wire to all speakers, then a 1000 watt 2 channle and 2 12's.
I love how it sounds loud, lots of bass but still sounds excelent.
98civdx is offline
Old 07-15-2010, 05:50 AM
what he said
wyldeman50 is offline
goldsy
Honda CR-V & Element
01-05-2014 11:33 AM
rfdphoto
09-11-2012 02:39 AM
euroborn1
08-27-2008 10:36 AM
Samcrac
04-13-2006 12:58 PM
NiiS
09-17-2002 10:12 AM
Quick Reply: I wanna put some sound in my car dont know where to start
  • Ask a Question
Question Title:
Description:
