How to add extra siren to DEI alarm.
I have a dei viper which I wanted to add a extra siren too. I was told to just cut the wire from where my exisiting siren is and connect the second siren's wire red to red and black to black with some plastic (nipples) and found a secure place to mount it. Is this correct? Thanks in advance.
New User
Re: How to add extra siren to DEI alarm. (00SilverLS)
The red is the trigger wire and the black is just ground. If you're really paranoid then run the black wire directly to the battery ground post. That way if they cut the factory ground the siren will still go off. Use loom if you can, it will protect the wires from heat, also I would suggest soldering and heat shrink all connections.
Re: How to add extra siren to DEI alarm. (Teken)
Usually running 2 sirens should be safe, but if you are running more than 2, you may want to use the siren output to trigger the other sirens off of a relay hooked directly to 12V.
dohctor_B
Audio / Security / Video
07-29-2012 05:43 PM
BlitzSix
17
05-18-2007 09:25 AM
