Honda Civic 96-98 Speakers
Hello, so i have a civic 96-98 and my 2 front speakers are not working well, I just bought new ones to replace the olds but i think the problem is the cable because when i touch the cable it starts working. I've googled about this but I can't find the solution. How can i replace the older cable for a new one? i know some dudes make a hole for a wider cable i dont mind doing that but i dont know where that cable end, where do i plug it?
Old Fart
Re: Honda Civic 96-98 Speakers
Need more info, was it stock speakers with stock speaker wire?
Is it a stock radio?
Stock speaker leads start at the radio plug on the back of the radio and run into the doors, the only connections will be at the door jamb boot, [door harness plug].
Where are you "touching" the speaker leads to get the speaker to work? 94
So i will get a new cable and make the connection direct to the radio and see if it works. thank you!
how would i go about installing new 6 1/2'' door speakers in my 6th gen. coupe? tell me if this is c
VTECcivicDOWORK
Audio / Security / Video
03-13-2008 02:50 PM
