Help with Main Relay Kill
I am trying to make a main relay kill, so that when my Viper 5000 alarm is armed, the main relay is killed.
How It's Wired Right Now https://cimg7.ibsrv.net/gimg/honda-t...d5b875ca2f.gif Problem: The car won't start and I can't hear the fuel pump prime when I turn the key to the (II) position. Also, does "Dash Side" mean the plug side (the short wire) and pin 87a is the rest of the wiring? BTW The car worked fine before I did this. |
Dash side is the end that goes to the dash but you have the wrong diagram for a main relay kill
30 and 87a are for the main relay black wire 86 is true ignition GWA from alarm to 85 Also, relocate the main relay. Grounding it will bypass this trick. |
Re: Help with Main Relay Kill
why don't you just have a stealth rocker switch, using the ground of the PGFMI relay....instead of the power? That's what I've always used and you don't have to worry about coming off and shorting itself out.
Originally Posted by NVturbo
(Post 50327865)
