DEI 530T and 529T installation in DC Integra?
#26
Re: DEI 530T and 529T installation in DC Integra?
Do not install it in the door. Always run the wires from the motor into the vehicle. I went to the junk yard and got oem honda extra pins to plug into the molex plug. Get the larger ones for the motor and the smaller ones for the switch. The 530t will sense someones arm and stop because of the resistance. For this reason it is also wise to clean the window tracks frequently and use the proper resistance settings with the dip switches for the type of vehicle it is installed in. You will also see the benefit of auto up and down from the drivers switch for the 2 or 4 windows the modules are for. 1 530t for 2 windows up & down. 1 529t for sunroof or rear sliding window such as a Tundra.
Do I need 2 aux channels if I use 2 modules for 4 windows? Or a single aux controls both modules is fine? How would I wire the modules up?
So how many wires do I need to run through each doors? 2 or 4?
Thanks.
#27
Get the pins with a few inches of wire and yes it is so there are no wires to cut or extra holes to make between the door and jam. I made mine to be plug and play. You will notice that there are holes for extra wires in the plugs at both ends of the door harness. You need two wires for the switch and two wires for the motor since you are basically splitting them in half so that the 530t can control them. The passenger windowns can be traced in the cabin near the kick panel. Make sure the ground wires are on bare metal.
#28
Hey I really appreciate your help. Where about are you in CA?
Thanks.
#29
Sorry I can see the extra plugs to avoid cutting but I can't visualize how the 2 sets of up/down wires go into the door between the motor and switch? Perhaps a diagram or even some photos from you work might help me see them.
There is a molex connector in the door with extra holes for additional pins. You still need to run wires from the cabin, through the door boot to the connector, and from the interior of the door to whatever option you're installing.
The lazy way is to drill a hole in the connector through some of the space used by the extra pin holes. The person who sourced the proper pins did this correctly.
On a model lacking power features (CX, DX, etc.), the connector is different (small 2-pin for door speakers), and there is ample space to run additional wires without having to deal with pins or drilling holes.
#30
If you go on Ebay and search for door harnesses for Integras or Civic's with power features, it'll make more sense.
Thanks.
#31
Hey,
What about the passenger's door? Do I have to run 4 wires into the passenger's door too? Or could I some how tap the wires for that door from the driver's side? I hate to run long wires across from the module to the passenger's door.
Thanks.
Thanks.
#32
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
This is real easy. Either put the unit in the door and run your trigger wires and atleast a 10g power for the unit. You can get your power source from the thick 12 volt battery wire at the fuse box. Reason is that low voltage kills power windows motors. The car is not running. And the unit has to power itself and two windows. You do not have to run any other wires into the other door unless you want one touch on the second door.
#33
#34
Thanks for the help. I know you are very busy.
#35
#36
Glad to see this post is still getting some usage.
FWIW Both modules are still running fine. I'm not sure what all the sunroof issues were about, but as long as you are driving the motor directly, post switch, you shouldn't have a problem with overrun.
Drilling the holes for the wires was the hardest part. My door is still not on straight.
#37
Integra sedans have overrun switches but coupes do not. Confirmed this with the Helms manual.
The 529T either doesn't have built in resistance detection as claimed or it doesn't work. The 530T built in resistance works poorly on Honda made vehicles and others that have lots of resistance to rolling them up. You might as well save your money and use your own relays.
#38
Yeah, I've learned to NEVER take off the door. Take off the fender instead. Much much easier with the door hung the whole time (though removing the fender is a PITA) and no door alignment issues.
1) How many relays do I need in each door?
2) How do I wire them up to work with the alarm system?
3) With the relays, will it has resistant limiter so it does not overrun and damage the motors?
Thanks.
#39
Hey so I've got a couple questions about my DEI 529.
1. I have a 2001 honda civic ex sedan and I cant figure out what color wires run to my sunroof and where I should tap into them.
2. Also, because there 2 buttons to use my sunroof there is a button to push my roof back and one to vent it should I have gotten a 530 or can I use the 529 for both? Thanks.
naahnaah
04-26-2011 09:31 PM
