Civic EK Where is central locking unit?
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Re: Civic EK Where is central locking unit? (fil2000ad)
The main locking unit is in the driver door. Its a brown box. But if your doing a alarm you can get the wires to unlock and lock the doors in the drivers kick pannel or the factory security plug. Also the triggers only test with the passanger door.
Re: Civic EK Where is central locking unit? (wrx-killer-Sti-eater)
Thanks.
So where is the best place to connect the keyless door wires?
Do i connect them off the interior fuse box?
driver kick pannel is the best spot if your doing a stealth install. The factory plug for the fatory alarm stick out like a sore thumb.
Looked everywhere under driver kick panel, can't find stock plug anywhere.
Remember its a U.K spec Ek so the interior fuse box is on the right same as wheel, would it be on the left (us drivers side?)
heres 96, after that it jumps to 03 maybe this will help.
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC (UK) / 1996 / Remote Start
[PRINT THIS PAGE]
12volts
Starter black/white ignition harness
Second Starter
Ignition black/yellow ignition harness
Second Ignition
Third Ignition
Accessory yellow ignition harness
Second Accessory wht/blk or wht/red ignition harness
Keysense
Power Lock grn/red/silver rings - 16 way plug, top of DKP
Notes: Pulse neg. once to lock and pulse again to unlock.
Power Unlock same wire
Lock Motor
Unlock Motor
Parking Lights+ grn/yel & grn/blu at stalk switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger green/red - driver side A pillar
Dome Supervision
Trunk/Hatch Pin grn/blk or green driver door sill
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue at the distributor
Wait to start
Brake Wire grn/wht or grn/blu brake pedal switch
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Modules: Not Available
Smart Starter Kill Relays: Not Available
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
[PRINT THIS PAGE]
12volts
Second Starter
Second Ignition
Third Ignition
Keysense
Lock Motor
Unlock Motor
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Dome Supervision
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Wait to start
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Old Fart
In the 98 USDM Civic it is a green/white for lock and a green/orange for unlock in blue plug in drivers kick panel, [left side] or at the green alarm plug behind radio.
You should also find the green/white and green/orange coming from the drivers door harness, unless your 98 UK Civic is like a 96 UK Civics one wire system.
Why not just pull the power door lock switch in the drivers door and see what color the wires are there. 94
Re: Civic EK Where is central locking unit? (fcm)
Right.
Took door trim off, found keyless relay.
Tried alarm wires on each wire off relay, could't get both doors to trigger.
Disconnected drivers door lock harness on door & the passenger unlocked & locked fine.
Both door locks work fine so i know its not the motors.
Can't seem to get both doors to lock/unlock together.
Also found a 3 wire plug under passenger dash (left side) with Blue/White, Blue/Red, Black/Yellow.
Tried alarm wires on these and also did't work.
Car is 1998 U.K Civic Ek
Viper 350HV
Viper 350HV
Old Fart
OK, let me try it this way...
Does your car have a power door lock switch on the drivers door?
If so, does it lock and unlock both doors?
If so, how many wires are going to it and what color are they? 94
Re: Civic EK Where is central locking unit? (JSPECSIR)
Yes drivers door has power lock switch.
Yes it locks & unlocks both doors.
9 wires go to it.
These are thicker wires:-
White/Red
Yellow/Red
White/Green
Black
Blue/Red
Blue/Red
Blue/White
Green/Red
Black/Yellow
9 wires go to it.
White/Red
Yellow/Red
White/Green
Black
Blue/Red
Blue/Red
Blue/White
Green/Red
Black/Yellow
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fil2000ad »</TD></TR><TR><TD CLASS="quote">Power windows work fine without relay being attached.
Doors do not function with relay disconnected.</TD></TR></TABLE> That's not what I asked. 94
no the door swith is seperate
don't know if this'll help but the 2 wires going to passenger door motor are:-
Yellow/Red (looks like 1.5mm wire)
White/Red
White/Red
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fil2000ad »</TD></TR><TR><TD CLASS="quote">no the door swith is seperate
White/Red
</TD></TR></TABLE> How many wires/what colors on the power door lock switch.
The two leads going to the pass. actuator, [yellow/red and white/red] are the same as the USDM and CDM 96-98 Civics, 94-98 Integra, 90-93 Integra and 91-95 Legend, probably the same on a lot of Honda/Acura.
My wiring diagrams do not indicate there is a power door lock switch in the pass. front door, only the drivers door.
The power door lock switch in the drivers door has 3 wires going to it
Black, ground input.
Green/orange, unlock output.
Green/white, lock output
Do you not have a power door lock switch with those 3 wires going to it, in your drivers door?
Should look like this... http://cgi.ebay.com/ebaymotors...sting
White/Red
Yes the relay is only in the drivers door.
The relay has 9 wires going to it:-
WHITE/RED (1.5MM)
YELLOW/RED (1.5MM)
WHITE/GREEN (1.5MM)
BLACK (1.5MM)
GREEN/RED
BLUE/RED
BLUE/RED
BLACK/YELLOW
BLUE/WHITE
My door lock is same as in your link.
I've put a photo of the relay/wires in my 'garage' on this site, search 'fil2000ad'
WHITE/RED (1.5MM)
YELLOW/RED (1.5MM)
WHITE/GREEN (1.5MM)
BLACK (1.5MM)
GREEN/RED
BLUE/RED
BLUE/RED
BLACK/YELLOW
BLUE/WHITE
Old Fart
By relay you mean "Power Door Lock Control Unit", USDM and CDM "PDLCU" have
Green/white
Yellow/red
Blue/red
Black
White/red
Blue/yellow
Blue/white
Green/orange
White/green
Also 9 leads and although there are some color diff. I would be willing to bet it is the same system, the two leads you need to tag into are the ones you do not have, green/orange and green/white, possible your green/red and one of the blue/reds, as ours has only one blue/red and no green/red.
Now I will ask you one more time, how many wires are on the power door lock switch and what color are they, that's the switch on the drivers door by the door handle not the relays or anything else, just the switch????? 94
Green/white
Yellow/red
Blue/red
Black
White/red
Blue/yellow
Blue/white
Green/orange
White/green
5 wires go to door switch
Yellow/Red
White/Red
Black
Blue/Red
Blue/White
I connect alarm wires to blue/red & blue/white (driver door), this only locks & unlocks passenger door when door switch on drivers side is disconnected.
Yellow/Red
White/Red
Black
Blue/Red
Blue/White
Old Fart
Now that's completely diff. then the USDM/CDM power door lock switch on the drivers door, ours have only 3 wires, a ground input, [black] and the two outputs, [green/orange and green/white.
I have no idea why there are so many leads on your switch when the power door lock control module has the same number of leads as ours do.
With our switches the output leads go to the power door lock control module, and supply it with a ground when you flick the switch to lock or unlock.
Try metering the leads and see which ones go to ground when you flick the switch to lock and unlock, those would be the leads that the alarms neg.(-) door lock outputs would connect to. 94
i'll try metering them over the weekend
i don't understand why they'd be different either
i think we'll get there in the end
thanks for all your help fcm might post you on monday
hi mate
Did you find an answer for your central locking problem?
I have same issue as you and same wiring ( same colors )
I can lock and unlock the passenger side but can not unlock the driver side with my new alarm.
Pls let me know if you have a solution for this
CR-V
10-26-2012 11:22 AM
fil2000ad
10-15-2007 01:45 PM
Slammed Ek9
Audio / Security / Video
03-15-2005 02:45 PM
