Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Audio / Security / Video (https://honda-tech.com/forums/audio-security-video-27/)
-   -   building a subwoofer enclosure (https://honda-tech.com/forums/audio-security-video-27/building-subwoofer-enclosure-1176771/)
idriveadelsol7 Mar 12, 2005 12:24 AM
i went to the store today and saw the enclosures they give away with the 12" jL audio W7... this thing doesn't look like it will fit into the trunk of a del sol because of its' height. i have all the materials. just need specs to work with... or somewhere i can buy a box that will fit. thank you
jdMaDDiCT666 Mar 12, 2005 07:45 AM
Re: building a subwoofer enclosure (hondaTheSun)
FIND THE SPECS OF THE SPEAKER ON JLAUDIO AND IM SURE FROM THAT YOU CAN BUILD A BOX THAT WILL FIT UR CAR IT WILL TELL YOU THE MINIUM SIZE THAT YOU CAN BUILD THAT BOX....GO OIN THE WEBSITE AND BUILD IT TO TRUNK SIZE AND SEE IF IT WORKS OUT ......
fcm Mar 12, 2005 10:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaTheSun &raquo;</TD></TR><TR><TD CLASS="quote">i went to the store today and saw the enclosures they give away with the 12" jL audio W7... this thing doesn't look like it will fit into the trunk of a del sol because of its' height. i have all the materials. just need specs to work with... or somewhere i can buy a box that will fit. thank you</TD></TR></TABLE> Go to http://www.jlaudio.com all the help you need https://honda-tech.com/forums/images/smilies/emwink.gif 94
idriveadelsol7 Mar 13, 2005 01:33 AM
Re: building a subwoofer enclosure (fcm)
i want something to fit in the trunk of a deL soL. i'm afraid i'm going to mess up and that 12" jL w7 won't sound it's best.
ballplayer Mar 13, 2005 03:46 AM
Re: building a subwoofer enclosure (deLsoL7)
just look up the specs from the site like they already said, and just make sure that when you build the box, it has the recomended airspace for that speaker. I believe The W7's require a shit load of airspace, and if your not sure on how to figure it out, you can go to http://www.the12volt.com under the "volume calculator" section. All you do is type in the thickness, height, and width of the box in order to find out the interior airspace for that specific box. Good luck with it, and let us know how it comes out! https://honda-tech.com/forums/images/smilies/emthup.gif
fcm Mar 13, 2005 08:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deLsoL7 &raquo;</TD></TR><TR><TD CLASS="quote">i want something to fit in the trunk of a deL soL. i'm afraid i'm going to mess up and that 12" jL w7 won't sound it's best.</TD></TR></TABLE>You may have to go with fiberglass to get the room you need, not hard to do, messy , and will take some time, but may be the only way. If you search, you can find lots of good sites on fiberglasing. https://honda-tech.com/forums/images...s/emsmilep.gif 94
