04 civic radio in eg civic
Old Fart
Re: (go2sleep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by go2sleep »</TD></TR><TR><TD CLASS="quote">they dont appear the same. is there a way to get the 04 harness and splice into the eg civic?</TD></TR></TABLE>The best way is to get an adpt. harness for you car and a reverse harness for the HU connect the two harnesses together, color for color, then its plug and play, but they should be the same, from 97/98 and newer all Honda/Acuras use the same 16 pin plug, [two uniform and spaced rows of 8 pins] from 86 to 97/98 all Honda/Acuras used the same 16 pin plug, [not so uniform kind of one row of 4 space 4 and a 2nd row of 3 space 2 space 3] you can see this at http://www.installdr.com click on quick radio wiring info. there is also a 3rd plug used on some 96 and newer Honda/Isuzus its a 14 pin plug. The adpt. harnesses can be gotten at any car audio shop. 94
1 point 6
10-06-2005 08:19 AM
frostcivic
06-28-2004 12:57 PM
