TK's CRX
#215
Re: TK's CRX
#217
#220
footwork mastery
Re: TK's CRX
Had to come find your thread, so how'd you get the 15x9 on the stock fender? Just a lot of rolling and pulling? Those aren't the carbon fiber ones anymore are they?
#221
Re: TK's CRX
they are 15x9" +36
the offset is the key here.
use 6mm spacer in front, they fit fronts with no rolling. I just hammered the lip flat in front... the rear i added 7mm of spacers.. had to grind some of the upper LCA and roll the fenders. I run 225.45.15 rivals and nothing rubs. my car is low also.
#223
footwork mastery
Re: TK's CRX
Wow didn't realize you got the 15x9 in the rear! Luckily my fronts fit with no spacer. Using Mini cooper rotors with a 3mm spacer behind the rotor for proper pad seating + their thicker rotor hat makes for a spacer itself.
Might have to try a wider rear!
#224
Re: TK's CRX
Try it out man, it's worth it!
yellowcrx1991
46
09-28-2004 10:40 PM
