SHG is back! Easy's EP3 goes under the knife...
Old 01-26-2012, 03:38 AM
  #2001
SHG_EasyE's Avatar
Default Re: SHG is back! Easy's EP3 goes under the knife...
I would recommend RSD or mono Flex. Both come with decent rates for street tires, are rebuildable, and have good quality monotube dampers. Ride height is adjustable independently etc etc. You really cannot go wrong. Both also have teflon coated shock bodies which will prevent rusting in the winter months.
Your buddy may need more camber in the rear, like 2-2.5 to clear with those wheels/tires. At my height I needed 3.2 to clear a 17x8 +35 with a 235 Re11 (Evo wheels that I test fitted)
Old 01-26-2012, 08:02 AM
  #2002
MissShift's Avatar
I was mainly worried with clearing any internal suspension parts being it +45 offset and 8.5 rim? So RSD over kwv2? Looking to purchase spring once I sell the rpf1s
Old 01-26-2012, 03:40 PM
  #2003
SHG_EasyE's Avatar
Oh, couldnt tell you clearance wise. Check the fitment thread on ephatch...
Well i thought you had decided against V2 because they couldnt get you stiff enough rates? I would use RSD over V2. RSD had separate height adjustment, inverted struts, and corrected steering arms, with arguably the same quality internals. Plus, they are about $400 less.
Old 01-26-2012, 11:15 PM
  #2004
MissShift's Avatar
I got quoted $1700 for V2. 400$ less for RSD? link? contact?
Old 01-27-2012, 07:10 AM
  #2005
SHG_EasyE's Avatar
I was basing that off of the 2k plus shipping I was seeing elsewhere when looking at suspension options for the DC5. Regardless even at the same price point I would personally run RSD.
Old 01-27-2012, 09:58 AM
  #2006
MissShift's Avatar
Sounds great! Looking like i found my Suspension setup this spring. BTW RSX vs EP3 RSD? Difference? Heard RSX is the way to go cause you can upgrade tierods? any other tips if you do recommend rsx rsd over ep3 rsd?
Old 01-27-2012, 10:44 AM
  #2007
<StevieG>'s Avatar
this post is <StevieG> approved.. the rsd's are amazing!
Old 01-27-2012, 07:07 PM
  #2008
chairwitharmrests's Avatar
I hear mixed things about those and the n+'s, if you look around there are some horror stories that a few have experienced with them. Regardless of that if I found a low mileage set of RSD's i'd snag them, but when it comes to buying new AMR has my interest right now, you pick your spring rates and they have a lifetime warranty for whatever that is worth...
Old 01-27-2012, 07:13 PM
  #2009
SHG_EasyE's Avatar
Yeah, youre right about the tie rods. But you cant use the TypeS rear shocks on EP3 suspension, the bottom bushings are wider. You can put together a custom TypeS front/EP3 rear damper set from Buddy Club USA. Shoot me a message if you decide to put in an order
Old 01-27-2012, 07:44 PM
  #2010
SHG_EasyE's Avatar
I dont want people to think Im just hyping up Buddy Club. Ever since my good friend owned a set of N+ back in 06, every one Ive known ever since that owned Bc has had great results as well as my own experience. Ill only support parts Ive had positive experience with
Old 01-27-2012, 07:47 PM
  #2011
You read my mind lol, j/k
They haven't been around for so long for no reason...
Old 01-27-2012, 09:56 PM
  #2012
SHG_EasyE's Avatar
Been busy lately!
Got the AC line welded up, here it is with the argon back purge so the weld is smooth on the inside of the tube
Welded up and installed. Perfect fit!
Also got the front shocks apart to install the new top hats, and machined the upper threaded mounts down to clear the shock towers
Old 01-28-2012, 12:15 PM
  #2013
MJ23FE's Avatar
E, are you going to paint the lower shock bodies? I see some surface rust on them. Would be a good time to freshen them up.
-Jalal
Old 01-28-2012, 05:31 PM
  #2014
SHG_EasyE's Avatar
Yeah, Im probably just going to touch them up with some POR15.
Old 01-28-2012, 05:34 PM
  #2015
ReedMann's Avatar
Looks great man.
Old 01-29-2012, 02:42 PM
  #2016
<StevieG>'s Avatar
Originally Posted by ReedMann
Looks great man.
Old 01-31-2012, 12:52 PM
  #2017
MissShift's Avatar
I found a used pair of Ohlins Suspension at a local JDM shop. Looks to be in good condition and owner of JDM gives it a 60 day warrenty when I called to check up on them. I remember my friend recommending Ohlins back in the day but researching it, I found the new price to be out of my reach. Now these pop up and I can't seem to resist? (I would also note these are for DC5 - I'm guessing just a change of something in the rear suspension to make these fit?)
Old 01-31-2012, 03:08 PM
  #2018
SHG_EasyE's Avatar
If the price is right, and you can have them rebuilt then go for it. If they arent rebuildable, or the rebuild cost is crazy expensive I would pass. I dont know much about them, other than I know ohlins makes great stuff. As far as the DC5 fitment, you will need TypeS tie rod ends and to shave down the rear lower shock bushings to fit the EP3 arms.
Old 01-31-2012, 09:52 PM
  #2019
SHG_EasyE's Avatar
Pretty excited about this update! Getting so much done on the car it feels good! My rear shocks are done at AST and should be here late this week. I was getting some leaking from one of the rears so I sent both in and they inspected and repaired them free of charge.
So since I just installed the SHG Rocker Cover, I wanted to re loom the top side engine harness so I could ditch the plastic guide that would have chafed the new paint. I decided to experiment with a motorsports style loom. I heatshrunk the harness, and used glue lined shrink to seal up all the joints. Im loving how it came out, Ill be doing my A2 harness and the DC5 harness like this too with a few more features
Then I was able to press in the new Buddy Club P1 ball joints. Im really liking the design of these. They have huge lower control arm correction, but moderate roll center correction. This keeps the front roll center low while also getting the arms horizontal.
Here is my old Hardrace part on the left vs the Buddy Club part which moves the joint 10mm down (roll center) vs the Hardrace's 15mm. Overall length of the P1 is 7mm longer giving more LCA correction.
Old 01-31-2012, 10:57 PM
  #2020
nice
Old 02-02-2012, 02:32 PM
  #2021
elsicario12's Avatar
cool!!
Old 02-02-2012, 03:46 PM
  #2022
SHG_Mike's Avatar
Moog is def getting that treatment
Old 02-03-2012, 05:37 PM
  #2023
dingo ate my baby's Avatar
awww yeah Ev killing it as usual. <3
Old 02-04-2012, 09:20 AM
  #2024
LankorDie's Avatar
x7
Old 02-07-2012, 07:18 PM
  #2025
back_woods's Avatar
Took 3 days but I went through every page. Awesome build, pretty much everything I dig about the honda scene. When I find other like minded people it gives me hope. Great stuff all the way through. I plan on starting one for my dc5 on here sometime soon. I started one on NWP but purpose built cars or daily drivers don't seem to get much love on there. Thanks for the inspiration.
Quick Reply: SHG is back! Easy's EP3 goes under the knife...
