SHG is back! Easy's EP3 goes under the knife...
#1179
1 Post
Re: SHG is back! Easy's EP3 goes under the knife...
Thanks guys
ordered up a buddy club batter, tie down, and some carbon for the din blockoff. So excited for parts to start coming in!
#1181
Guessing most control is gonna be done with the IPOD once driving. Looks good though. I like being able to see and reach the headunit or I would do something like this.
#1183
Great work, but what about when you want to listen to the radio? Or shut the HU off? Idk. You could have recessed the deck a bit in the dash and found a way to make a slider out of carbon to hide the radio when not in use...or when it's on the source you're using.
Nice work as always, though.
-Jalal
-Jalal
#1184
1 Post
-Jalal
-Jalal
Sliding panel coul have worked but I would have been complicated delicate and not as clean as what I'm going to do. The main reason I did this was to achieve a look for the dash I've been envisioning. It's going to look pretty sick when its done
#1186
where would there be room for a sliding cover? Let the eye of the beholder do his duty! Just joken around......lol
#1188
1 Post
Yeah, theres the room thing too. Idk a sliding cover would just be over engineered in a way. Thanks for the replies guys!
Hoping to get some more done on the car tonight, Ill def have another update coming
#1193
#1195
If that's all to need it for than that works! A little sliding CF action would have been sweet, too. I can't wait to see what the dash looks like. Either way. Your work is great!
-Jalal
-Jalal
#1197
1 Post
So Ive been spending time working on my 05 Type S manifold and cat in preparation for the Buddy Club exhaust here and there, and its finally ready to be installed
I decided to grind down the intrusive runner welds at the flange to create less turbulence in the manifold, and welded the outsides for strength.
Then I added a bung to the down pipe to measure air fuel ratio on the dyno, and also put some new bolts on the heat shield.
Ill leave you with a picture of the car in the new garage about to go back on jackstands
