my very basic ls turbo build thread.
back to boost for me :)
1990 ls motor ($200) 8lb flywheel act 4 puck sprung clutch gsr tranny from last build welded diff (love it) ebay cast iron mani ebay 38mm waste gate with vac bolt shaved down so it wont rub on the diaphram custom dump tube ebay ar.50 turbo 3" custom open down pipe, bumper exit mild steel charge pipes oil restrictor dsm 450cc injectors gm 3 bar map s300 with boost by gear goals are 275-300whp and traction. all I want is 12's on street tires. my old all motor ls, ported head, gude performance cams, 8k all day http://i47.photobucket.com/albums/f1...0724091655.jpg http://i47.photobucket.com/albums/f1...813091743a.jpg working on shaving / tucking the bay http://i47.photobucket.com/albums/f1...enginebay2.jpg http://i47.photobucket.com/albums/f1...205091452a.jpg http://i47.photobucket.com/albums/f1...1207090112.jpg worlds gayest valve cover lol http://i47.photobucket.com/albums/f1...1207091624.jpg waste gate dump tube,will be painted and wrapped with header wrap http://i47.photobucket.com/albums/f1...1207091805.jpg http://i47.photobucket.com/albums/f1...1207091856.jpg |
Re: my very basic ls turbo build thread.
lose the ebay 38wastegate.. next thing you know the gate wont open and your car will blow up.. i'll sell you a tial for 130shipped. 7psi spring.
used them before for over a year with out any problems. Iv had a tial 38 and a ebay, only diff was on the ebay the diaphram would rip because the bolt for the banjo fitting is too long so I shaved this one down so it wont rub.
just my .02cents. its like taking a risk with ebay junk tho... but do as you please.
a few more pics
http://i47.photobucket.com/albums/f1...1207092302.jpg http://i47.photobucket.com/albums/f1...207091624a.jpg gonna start fabbing up the down pipe today, unfortunately its about 22 degrees out :s |
today was FREAKIN COLD
im so tired of the 20 degree weather around here, its the coldest its been in 11 years! so today I wasn't down to spend the whole day working on the hb but I did run a few errons and grab some small stuff that I needed, unfortunately the throttle body gasket I bought was a hunk of crap, it was a feelpro but the bolt holes were all off by about 1/4" so tomorrow I have to run to honda to get a new one. I also have to cut the radiator brackets because I had to cut them when I put my dc radiator in for my all motor setup. its extra work, but its all good since now I can move the radiator as far away from the turbo so the down pipe will clear it even better.I think Im gonna also make a custom radiator overflow that I can hide away some where. |
nice
u seold ur old ls head |
I sold my old ls longblock for $1100 lol :)
other wise I would have boosted that one, it ran hard as hell on a 85 wet shot |
started fabbing my downpipe today. its gonna be 3" out the bumper :)
http://i47.photobucket.com/albums/f1...1209091655.jpg http://i47.photobucket.com/albums/f1...1209091813.jpg |
is this a street car
of course.
Iv ran exhaust out the bumper on a sohc turbo I used to have and didnt have any issues with the po po's |
how loud is it
and is their a diy on welded diff or more info |
its actually quieter then like a normal under car open down pipe because it doesn't resonate the whole car. its also alot better on fumes and exhaust ..etc
as for the welded diff, if you know how to take the diff out of the tranny then all you have to do is weld the two spider gears to the drive gears, Iv put about 5k miles on mine with out any issues and I have a 231whp all motor b20 vtec in it. the welded diff makes parking lots kinda suck, but a hell of alot cheaper then buying a good lsd or spool. and if it breaks a stock diff isn't very expensive. it also greatly improved cornering in my car which I couldn't believe at first. its much more of a point and shoot car now. |
shits weak haha did you find that part?
Dang son i wished i would have bought the chrome EMUSA wastegate. Those are good wastesgates from what i hear. Me and two of my friends are using them.
only thing I dont like about my wastegate is it seems to sit up hella high so Im gonna have to cut out some of the hood support or prop the hood up or something. or just let the natural route of things go and have the w.g. beat the sh!t out of my hood lol.
and justin.... yur shits weak. Ima hit u up 2marro 2 get random assorted ls junk |
why didnt you paint the firewall>?!??!
really looking foward to this one
Originally Posted by maxwellmercer
(Post 40904519)
when you tuck your bay, where do you run the ac hoses? or do you do an ac delete? sorry im 15 and have a lot to learn.
no ac in my whip
get off your a$$ and work on your car
dude I can't see. burned the fuk out of my eyes. stupid welder.
new pic of the tube and fin intercooler mocked up.
http://i47.photobucket.com/albums/f1...1210092009.jpg |
let me know how the parts worked out
