my crx race car build thread
#227
Re: my crx race car build thread
question for you, did you paint your interior with spray paint, or with a gun, cause im in the process of prepping interior for fresh paint and am wondering if it came out that good with spray can, or a gun?
#228
derp resistant
it was rattle canned just so i can re touch it easier because interior gets ****ed up. but the reason it looks so good is all in prep work and using good primer.
#229
Ra-ta-ta-tat dat GDD
#230
cool good to know cause i dont have my compressor at my house, so did you sand down to the metal inside, or just clean really good? and if you sanded what grit did you use i will be doing all this by hand so if i do need to sand i will, but its going to suck, and what color is that for the interior it looks great, also what primer did you use?
#231
derp resistant
just remember, the quality of a paint job is only partially dictated by the spraying skills or the products you use, the real quality shines through in the prep work.
#232
well ive already got about 10 hrs of work into removing all the sound deadening by scraper, and steel wool, so i might as well finish it the right way, i planned on this being my winter project so looks like ive got my work ahead of me, thanks a lot for all the advise, it will for sure come out better the way you have explained it.
#233
derp resistant
#235
i scuffed it all down with 180 grit, made sure everything was dull and smooth, then i went over it all again with a red scotch brite pad to smooth it out, then i wiped it down really well with wax and grease remover. applied the first coat of sem high build primer, smoothed that out by sanding with 400 grit, wiped down with wax and grease again, another coat of primer, sanded again with 600, wiped down with wax and grease, then i applied sem gunmetal grey promax xrp enamel. about 4-5 coats of that, then i cleared it with sem promax enamel clear coat. about 5 coats of that too.
Cool
I’m about 6hrs in to prep on my cage, thanks for the answers
Seems the tubes have some type of coating on them and I was about to paint over it when a friend said just about the same thing you are saying.
Davegt27
#237
Who the fack changed my title?!
#239
derp resistant
painted the cage tonight
the masking
before
after
i am going to pull the plastic off by monday because its been so damn cold i want to give the paint some time to dry
the masking
before
after
#245
derp resistant
#248
derp resistant
