GreatWave's not-so-jdm Integra build
#680
Re: GreatWave's not-so-jdm Integra build
No, fortunately it was just the one front tire. But it really ******* got me on the side of the road this morning in the freezing cold wind. I had to catch a ride to the shop because I don't have a spare. It's safe to say I do now!
#681
Tire and wheels issues we're all taken care of this weekend. I straightened out the bent wheel, put on a new tire, balanced and rotated all 4. This morning I went out and finally installed my window visors! It's not super hard to do, I should probably do a write-up so there's some good info out there, but who knows if I will.
#682
Nice build! curious to how the Pheriable.net base map worked out for you, Im also using a base map from them but my engine runs pretty much perfect! it runs better than my last 3 dyno tuned setups! im on about 10-12 psi but my AFR are spot on and knock on wood I have no desire to have any one touch the tune! Sucks with photobucket! I had to do there temp hot link fix to restore all my lost photos, download them again to hondatech and post the pics from my albums it was a PITA! but now all my old lost photos are still on my thread.
#683
Last weekend I installed a factory throttle body bored 70->65 and ran into all sorts of idle issues. High idle, hunting idle, you name it. Ran through everything the FSM said to check regarding idle issues, no dice. Threw the Skunk2 70mm back on, not the first problem.
#685
I tore it all down yesterday and cleaned it, adjusted the throttle stop, adjusted the idle screw, and we'll try it again. I also managed to break my tps AND map connectors Saturday, so I'll be soldering them this morning before work
#687
New OEM oil pan should be headed my way anytime now. Time to seal up all of the oil leaks on this thing once and for all. Next weekend will also bring some major improvements in the looks department, but I'll wait to post pics when it's all done.
#689
Not yet, I need to call my friend at the dealership. I'll get the oil cooler o-ring, breather box o-ring, and I'll handle the rear main seal when I do the clutch. Cam seals, main seal, and valve cover gasket/grommets are all done!
#691
I have to receive it first lol. Two days later and it still hasn't shipped yet. I'm really hoping to have it by the weekend so I can install it. Then maybe I'll get around to a couple of other things that need done
#694
I've been meaning to make this post for probably a week and a half now? I got all the oil leaks sorted out on the Integra. I replaced the breather box o-ring, oil cooler o-ring, and oil pan and gasket. So far no drips. @danteisme and I believe @tamboo used this same exact oil pan from Amazon. It's sold as "OES", which I determined after a bit of research to be from the original supplier, so it's a real deal Honda pan.
#696
Attachment 510917
Attachment 510918
Attachment 510919
Attachment 510920
Attachment 510921
Attachment 510917
Attachment 510918
Attachment 510919
Attachment 510920
Attachment 510921
#698
My awesome fiance came in to the shop on Friday and had a super secret meeting with Aaron. After they were done talking, I was informed by both of them that she had just purchased the last two pieces of my body work puzzle!! Say hello to my new doors and hatch! Both are from a 96spec that we imported last month, and I'm fortunate enough that neither has damage or rust, and the hatch is (thankfully) lacking the wiper AND third brake light. Now I need to bust *** and get this thing done!
