EJ_Allmota | EJ1 Reincarnation
#101
Re: EJ_Allmota | EJ1 Reincarnation
If I had a nickel for everytime I was at this place where I had to pull everything back out! Good thing it was caught before real damage was done
The following 2 users liked this post by EJ_ALLMOTA:
#106
How she looked at the last track even back in May where i ran my new personal best 13.55, my first time out on slicks. Much more seat time needed, my goal is to break into the 12s on this setup.
Little panel to go in the radio slot on the dash that Ive been working on. It will hose my Oil pressure and Air/Fuel gauges as well as a switch for S300 Datalog as well as an ECU port. The plan now is to transfer this mock up to plexiglass or some other material. I don't really care to do carbon fiber like everyone else does.
#114
Can’t wait to see more from this.
are you running those bloxs lug nuts? I had a set in the past and never had any luck with mine.
#115
#116
Got my homie to wrap my roof on the car a couple days ago. Its a look I've always envisioned for the build.
#118
My tuner messed with the tune to make the loping more pronounced.. It can be tuned to idle smooth..
My little project that turned out pretty good.. Made this headlight duct out of a piece of sheet metal we had laying around the shop.. Started with cardboard pieced after I removed the glass off the headlight..
#119
Shot from the drag strip back in November when i got the car down to a 12.77 at 105mph in the 1/4 mile.
#121
Decided I wanted to go a little bigger with my headlight intake for this race season to see if i could squeeze a little more power out of my LSVtec setup. I had my brotha at EBTEC weld up the piping after I did all the mock up work. My old headlight duct with straight 3in piping. The new setup is 4in stepped down to 3.5in all Vibrant Performance piping. 4in Opening at the headlight rear, I had to transfer the front duct from the old headlight because it wasn't as simple as just making the old headlight housing bigger. Should be putting the car back on the dyno to see if the added air volume makes a noticeable difference.
#125
Decided I'd give Snowite some upgrades. Most people leave stopping power until the have a ton of power to try and stop. I decided i'll get it out of the way since I got a really great deal on a new Wilwood DPHA kit. It was very interesting to find out that the Wilwood calipers (4lbs) were exactly half the weight at the factory GSR calipers (8lbs). I haven't driven the car yet since putting them on but I know they will look great behind my RPF1s, Traklite Lauch Slicks and Slipstreams. Also recently purchased a Skunk2 Ultra Street intake manifold (not yet installed) to see if I can squeeze some more power of this 1.8L LSVtec setup before I build a B20 bottom end this winter.
by Khris H, on Flickr
